performa built fail
Old 08-13-2012, 08:26 PM
  #81
Jake's Performance's Avatar
Originally Posted by performabuilt
I would guess a failed converter sprag as the splines are not stripped but as I said we will not know till we cut it.
Just wanted to update everyone as promised.
Frank @ PerformaBuilt
A failed converter sprag will not cause a no movement condition. It will change the stall speed but the car will still move.
Old 08-13-2012, 09:55 PM
  #82
LS1Tech Sponsor
performabuilt's Avatar
Like I said just a guess the only thing I know right now for sure is the trans was perfect inside did work with our test converter fine. But as we did not get the trans back at same time as converter when we tested with returned converter trans will not move at all. But inspection of the splines show fine, Will know more once the converter is cut.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 08-13-2012, 10:55 PM
  #83
bmf5150's Avatar
I have franks level 2 4l60 in my 68 camaro for about a year now,I have had zero issues with it!its mainly a street car!also everytime I have called frank he has taken time to answer my questions!!
Old 08-13-2012, 11:15 PM
  #84
00MaroonZ28's Avatar
Originally Posted by mjs1012
Another performabuilt horror story.... That's the main reason I went with FLT. the fact that they test all their transmissions before shipping them out was a nice reassurance for me. I also placed my order with finish line and had to wait a month for mine to be built, not a few days...
I went with FLT also. Went down to Chicago to pick up the transmission personally and got to take a tour of the shop and how they build all their units. Great guys and cool shop. I've had my FLT Stg 6 for 3 years and it's been great. Took about a month but well worth it.
I'm thinking you didn't put enough transmission fluid in it also. Mine wasn't shifting into 4th after I installed it and put more fluid in their. Worked fine after.
Old 08-13-2012, 11:59 PM
  #85
Dan
Dan's Avatar
I have been waiting 6 Weeks for my FLT. I was starting to get worried, but reading the post above this seems to be the norm I guesss
Old 08-14-2012, 04:19 PM
  #86
BoostedBird's Avatar
R you serious! U my sir are a dumb ***! !!! He even admitted it was convertor failure an they are trying to make it right I know how to tell if there is enough fluid thanks for your nonsense
Old 08-14-2012, 04:21 PM
  #87
LS1Tech Sponsor
This is what we found broken just FYI and why the trans stopped moving.
Thanks
Frank
__________________
Call 888-744-6542
Old 08-14-2012, 04:31 PM
  #88
Exeodus's Avatar
Originally Posted by BoostedBird
R you serious! U my sir are a dump ***! !!! He even admitted it was convertor failure an they are trying to make it right I know how to till if there is enough fluid thanks for your nonsense
What's a "dump ***"?
Old 08-14-2012, 04:39 PM
  #89
That's what happens when ur setting in a Dozer trying to operate it an text on a phone with a broken screen
Old 08-14-2012, 05:37 PM
  #90
dlandsvZ28's Avatar
Thanks
Frank
For those of us who know nothing about converters, can someone please explain what happened to this converter?
Based on the OP, the car didn't even make it into 1 1/2 miles before it broke.
With the millions and millions of converters in cars today and their reliability, what caused this to happen to this particular
converter?
http://blogs.howstuffworks.com/2009/...onverter-work/
Old 08-14-2012, 08:06 PM
  #91
LS1Tech Sponsor
You are seeing the hub broken loose from the turbine , As for why no idea we have actually not had this before.
__________________
Call 888-744-6542
Old 08-14-2012, 09:35 PM
  #92
SnIpEz's Avatar
Who made the converter? Sounds like the welds did not penetrate very deep and it broke under a hard acceleration
Old 08-14-2012, 11:26 PM
  #93
dlandsvZ28's Avatar
How would one go about installing the second tranmission's splined shaft into the turbine's output shaft if it was broken completely apart from the turbine as shown in the pic?
Old 08-14-2012, 11:41 PM
  #94
SparkyJJO's Avatar
I suspect when it is all together the shaft is still held in place, just no longer attached to the turbine so it is just sitting there.
Old 08-15-2012, 03:48 AM
  #95
I'm just saying. Hell I thought I put enough fluid in mine and apparently it wasn't enought. I'm not bashing anyone here. My problem was similar with it going into gear and acting like it's in neutral. Great, you found out it was a converter failure. Congrats. It's not typical for a shop like them to have a bad transmission right out of the box. That's why I was thinking it was somewhere on the lines of someone elses fault. Apparently it was.
At least I can spell converter, dipshit.
Old 08-15-2012, 06:16 AM
  #96
LOL well like I said during the day I can't see what I am typing because I have a broken screen! But hey I apologize for being rude just so tired of hearing dumb comments about being installed wrong! Its not hard to install a Trans! And right before your comment Frank said they found it was the convertor fault.....
Old 08-16-2012, 02:35 AM
  #97
No big deal. I honeslty didn't see the post where he said the converter broke since I didn't get that far in the thread. I've never heard of a converter breaking at the hub and rare a transmission to be broke after a mile of use. That's why from my experience I could only think of something with the installation. Hope it gets done soon and you get back on the road. Good luck.
Old 08-16-2012, 08:25 AM
  #98
98cobrakiller's Avatar
i a performabuilt stage 3 with a yank ss4000 love them both
Old 08-17-2012, 08:28 PM
  #99
99_pewterZ_A4's Avatar
What brand of converter was this that broke???
Old 08-17-2012, 10:23 PM
  #100
it one of there in house brands
Quick Reply: performa built fail
