08 5.3 4l60e tranny. will it work with an older harness?
I found a good deal on this 08 5.3 / 4l60e tranny with 40k miles. I am doing a ls Swap into my 69 camaro. I have several truck harnesses from 99, 02, 04 with dbw & dbc. I.also have a 99 ls1/a4 harness. Will any of these harnesses work with this tranny? If not up to what years would work or what wont work?
All those harnesses should work with the 08 it just has the extra pins for ISS. The later 09 ones are different internally and missing some things over the earlier ones.
This explains it better. https://ls1tech.com/forums/pcm-diagn...cs-2008-a.html
It should be a 60e M30. The 70e was used with the 6.0L in the 1500 trucks.
