Want to get my speedometer back after a th400 swap
Old Nov 13, 2012 | 05:40 PM
LSXBlazer's Avatar
Default Want to get my speedometer back after a th400 swap
Anyone know what I can do to hook up my factory speedo to my turbo 400 trans. It's a 1998 z28 with a modified 98 harness and an 02 PCM. I do not have abs now. I would like to use one of the front wheel speed sensors to get my signal for the speedo. Anyone done this? Thanks
Old Nov 13, 2012 | 05:46 PM
Bo185's Avatar
Why not just use an inline speedo cable VSS like Jags that run or Dakota digital sale?
Old Nov 13, 2012 | 05:56 PM
LSXBlazer's Avatar
I have a rossler turbo 400 that has no cable drive assembly nor the proper tail shaft housing to hook one up.
Old Nov 13, 2012 | 07:12 PM
GMRACER13's Avatar
https://ls1tech.com/forums/automatic...400-w-vss.html
And...
https://ls1tech.com/forums/automatic...-question.html
Old Nov 13, 2012 | 11:35 PM
3rdgen92maro's Avatar
I did it in my car. Worked like a champ as long as you adjust the speedo table in hp tuners.
Old Nov 14, 2012 | 04:48 PM
FTICONVERTERS's Avatar
LS1Tech Sponsor
The speedo in a 400 goes in the case not the tail. Prolly has a freeze plug installed there.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Nov 14, 2012 | 08:51 PM
Slowhawk's Avatar
LS1Tech Sponsor
I just put a reluctor wheel from Midwest chassis on my rear end yoke. Made a bracket to hold the sensor. Works great. I'd rather have it for the rear tires than front.
Old Nov 15, 2012 | 08:09 AM
GMRACER13's Avatar
Why does everybody try to get all elaborate? The TH400 came in vehicles with electronic speedometers. All you need is the STOCK reluctor wheel and the STOCK vehicle speed sensor. The only thing you need to modify/change is the plug on the harness so it will plug into the older style VSS. Hell, if your car was originally equipped with a 4L60E (or an 80E for you truck guys) then you don't even need to do any tuning. It boggles my mind that people are jumping through hoops or trying to reinvent the wheel when it comes to getting the speedo to work after a TH400 swap. It's soooo simple.
Old Nov 15, 2012 | 09:33 PM
Slowhawk's Avatar
LS1Tech Sponsor
Because some people have the tranny's without the internal sensor already in there car. Obviously if the sensor or wheel was there they wouldn't look for other ways.
Old Nov 16, 2012 | 10:27 AM
GMRACER13's Avatar
Holy hell, so buy it and install it! It's a lot less hassle and expense then buying an aftermarket reluctor wheel set up and fabbing up some brackets to hold a sensor. Really, it's not hard and you don't even need to pull the tranny to do it.
Old Apr 1, 2015 | 08:10 PM
AINT SKEERED's Avatar
I'm going through Dakota digital with these 2 part numbers.
SGI-5 84.95
SEN-01-1 29.95
I am putting a 200 4r in my car and don't want to lose abs.ill report back when its finished but that will be a month or so.
Old Apr 4, 2015 | 11:25 AM
Kevin97ss's Avatar
SGI-5 84.95
SEN-01-1 29.95
Lonnie at Extreme Automatics built my 200-4r with a stock 4l60e speed sensor in the tail. ~$150 for the work and sensor.
Old Apr 4, 2015 | 02:12 PM
He is doing mine as well. I asked about it and he is who suggested Dakota digital.
Are you running one of his converters also?
Old Jun 11, 2015 | 03:02 PM
Update. The parts from dakota digital worked great. The 200-4r is bad a $$ .
Old Jun 11, 2015 | 09:47 PM
jrpimp00's Avatar
Jakes modified a stock 4l60e ring and put it in my 400. I found the sensor online and added a pigtail and my speedo works in my 98 TA
