tc swap questions
https://ls1tech.com/forums/automatic...allations.html
https://ls1tech.com/forums/automatic...all-video.html
Notice the important 1.125" distance between the converter pad and edge of the bell housing. (Put a long straight edge over the bell housing to make this measurement.)
Just to be safe, after getting trans aligned on the alignment pins and pushed toward the engine, only hand tighten a few bolts with no tools. Make sure the converter still spins by hand. Then tighten the bolts, making sure the converter always spins easy. Many people don't get the converter in all the way, don't measure the distance to the bell housing, torque the bell housing on and then discover they pinched the converter and ruined the transmissions pump. This cannot happen if you measure and make sure there is always a gap.
Then you need to measure the gap between the converter mounting pad and the flexplate. It should be between 1/16" and 3/16". Any more an you need to install three equal-thickness spacer washers to reduce the gap.
Good luck.
And ill have to watch that video and thanks for the video and info. There seems to be alot that can go worng
just my .02' Johnny
Once you install the 1st bolt into the converter, you need to turn the entire engine from the front crank bolt. Use a 24mm socket, a short extension and a long breaker bar. If it is too hard for you, remove the spark plugs.
Here are two other similar threads:
https://ls1tech.com/forums/automatic...lp-please.html
https://ls1tech.com/forums/automatic...ter-bolts.html
Remember the Red Loctite.
PM me if you would like my phone number for help while under the car.
