thoughts on locking up a high hp combo on the dyno?
no he means lock the converter at part throttle then go wide open throttle to dyno...
get it into 3rd gear, lock the converter, go wot to dyno
do not...
go wot and then lock the converter during the pull
The posi-loc clutch is designed to add some coupling pressure when the input shaft sees better than 450 ft/lbs of TQ (and thus this added coupling will lessen as the TQ falls.) That is NOT the same thing as locking the converter. You still need to manually lock the converter on the dyno even with a posi-loc clutch.
SC-
up to have the TCC lock at the top of 3rd for a
little more time-in-gear at the end of the 1/4.
I tried this on mine and it made some not-too-
happy noises. Are there converters you have had
to -not- do power clutch applies, or ones you
have found just won't hold against max output
and have to be "given up on"? Just wondering,
maybe mine is still sore from feeding it B&M fluid
in its youth.
It might help that I have the TCI shift kit and run F-type fluid, I dunno.
to raise the 3-4 shift point above 125MPH just because
the Predator would never let me. I thought maybe there
was some PCM limit to it. I will have to see what HPTuners
will let me get away with.
