TH400 newbie
Old Dec 16, 2012 | 01:53 PM
SCott5's Avatar
Default TH400 newbie
Okay. I been helping a friend with his fox lsx swap and for helping him out he gave me a th400. Now the thing is he has no idea about it, what it came out of, what year it is, basically just knows its a th400. I got it with the tranny and a basket of parts. Where do I even begin to start researching what I have? I work with a guy who used to do transmissions for a living and he said he would go through the box and everything to get me a run down of what is missing and what I have and need to buy.
So are there numbers somewhere on the tranny that I could search to get more info on the tranny?
Old Dec 16, 2012 | 02:51 PM
badhombre's Avatar
one big identifier is the tailshaft. if it is very short and has a yoke that bolts to the tailshaft, it is a truck/van tranny. the car ones used a standard style slip yoke
Old Dec 16, 2012 | 05:36 PM
RonSSNova's Avatar
There should be a 1" square tag on the sid of the trans held on by a rivet that will contain the info you need.
You will have to decode it.
Ron
Old Dec 16, 2012 | 06:11 PM
SCott5's Avatar
Its not put together. Its just the case and then all parts are in a basket
Old Dec 16, 2012 | 06:14 PM
SCott5's Avatar
I found the tag.
Numbers are 86 FMA 62461
I put them in google and came up with nothing. Anywhere else I could look?
Old Dec 16, 2012 | 06:41 PM
93camaro_zzz's Avatar
You should be able to identify the tail shaft. It will either be on that is 3" long or one that is I think 9" long. After that, there is not much else you need to figure out about it.
Old Dec 16, 2012 | 07:11 PM
RonSSNova's Avatar
86 is the year, so 1986.
FM means 350 V8 in a C30 series pickup.
Not sure about the A
From the Book How to work with and modify the TH400 by Ron Sessions.
Ron
Old Dec 16, 2012 | 07:25 PM
SCott5's Avatar
Yea I too am confused about the A.. The number on the tailshaft is 8624486 LESTER-8 which from what I am researching is a short tail
Old Dec 16, 2012 | 08:09 PM
RonSSNova's Avatar
Short tail is 4.25" long. The long ones were uncommon.
Trucks typically used a bolt on rear yoke because they had a 2 piece driveshaft. There is a difference in the trans output shaft, but can still be used for a car application.
