Doing my Jakes 4l80e swap soon. Anything I'm missing?
Old 10-18-2012, 01:45 PM
willizm's Avatar
Default Doing my Jakes 4l80e swap soon. Anything I'm missing?
Hi all, so my bother in law and I will be doing my 4l80e swap in the coming weeks and I believe I have all my bases covered, but if I'm missing something let me know. We got access to a lift and trans jake so I'm hoping everything will go smooth. I'm done swapping broke 4l60e's in and out every other month.
What I have ordered from Jakes:
Stg5 4l80e w/shoebrake2
BMR Crossmember
Derale Cooler(fan), lines, fittings
Yoke
Dipstick
What I ordered from Yank
PY3400 (6bolt converter)
Other stuff i've got
TCI flexplate for LS1/4l80e w/ 6bolt converters
14q of Castrol Dex/Merc ATF
Speartech 4l60e-4l80e harness adapter(still need to order)
I have also reached out to HPTuners support and they were able to do a segment swap on my tune file and got that back to me. I have the latest beta version of HPTuners so hoping I don't have that lockup issue others have had with older versions of HPTuners.
If I'm missing anything let me know. I have never done this swap and my hope is that I can plan enough ahead to make this smooth as possible.
Thanks
-Will
Old 10-18-2012, 02:05 PM
Heyfred's Avatar
Rear gear change.
Old 10-18-2012, 02:14 PM
mike13's Avatar
You don't need the speartech harness adaptor and you can run the 4L60E segment in your tune. Talk to slow67 all it takes is a couple of wires changed and a relay added. He's the guy that did all the hard thinking to make it work
Old 10-18-2012, 03:08 PM
DopeFedZ's Avatar
I didn't use the harness either. Just move a few wires add a relay and you run it off the 4L60 file/segment. Have a Jakes 80 as well no problem whatsoever. 4l60s were not lasting at all with the nitrous and the 80 hasn't skipped a beat.
Old 10-18-2012, 03:24 PM
willizm's Avatar
Is there any diagrams on how to setup the relay and re-pin the adapter? Thanks guys for the info BTW. Keep it coming
Old 10-18-2012, 03:52 PM
mike13's Avatar
I paid $20 to slow67 for the diagram and his help. I could've just got them from someone but it was worth the $20 he wanted just to get his help.
Old 10-18-2012, 05:19 PM
willizm's Avatar
So is the slow67 wire mod with relay a cheaper DIY variety to what the speartech harness does? Is there any difference between the two outside of the price difference? I don't recall seeing a relay on the speartech harness.
Old 10-18-2012, 05:50 PM
Gingervitis Addict
slow67's Avatar
One difference is with the speartech harness and an 80E tune, is the converter unlocks everytime you let off the gas. It doesn't do that with the 60E tune.
Also make sure your yoke matches your current u-joint, or get a conversion u-joint.
Old 10-19-2012, 10:38 AM
mike13's Avatar
willizm take my advice, I did the 4L80 swap, spend the $20 and get the diagram but more important is slow67 has spent alot of time studying the 4L80 and can help you if you have any issues.
Hey what's "shoebrake2"?
Old 10-19-2012, 11:09 AM
White.Lightning's Avatar
I'm gonna do the 60e/Slow67 mod as well.
Other than that, list looks good.
Old 10-19-2012, 12:51 PM
willizm's Avatar
Yeah I'm getting in contact with him to try it. The shoebrake2 is their forward gear trans brake. From what I gather it's rather new, but the benefit is that I can stage the car in 3, hold the button, build up some boost/rpm, let go and boogy. No shifting 1-2-3. The other trans brake requires you to stick it in 1st and shift it into 3rd while this one is a little more automated. Only caveat is that If I want to put the car in reverse I have to hold down the button.
Old 10-20-2012, 02:15 PM
ez2cdave's Avatar
Originally Posted by slow67
One difference is with the Speartech harness and an 80E tune, is the converter unlocks every time you let off the gas. It doesn't do that with the 60E tune.
What is the advantage or disadvantage to that ?
Old 10-20-2012, 03:40 PM
willizm's Avatar
I guess if you are cruising along and the converter is constantly locking and unlocking I could see how that would be very annoying. Maybe if you are in a roll race about the lockup speed, maybe it's not a bad thing lol
Old 10-20-2012, 07:20 PM
FrankSS's Avatar
why are you running a fan for the cooler? just peace of mind or what? Im looking to do this soon also while i have the trans out
Old 10-21-2012, 01:54 PM
LS6
LS6's Avatar
Have you complete the 4L80e swap with the re-progragm
Old 10-21-2012, 10:25 PM
willizm's Avatar
Not yet, I got my file segment swap. Just waiting on the trans which should ship Monday.
Old 10-22-2012, 06:30 AM
mikey zo6's Avatar
Good thing the "shoebrake2" was explained. I thought I was gona be cutting a hole in the floor to get all Fred Flintstone in the TA
Old 10-22-2012, 12:46 PM
Gingervitis Addict
slow67's Avatar
With an 80E tune (and any decent bigger converter), lets say you cruising down the highway. You come up to some traffic, and let off the throttle completely to slow down (but don't have to touch the brakes). You converter unlocks, and your engine revs up. Lets say the car that was going to be in your way moves out of the way. You get back in the throttle a little bit (enough to continue cruising again) and the converter has to re-lock.
With a 60E tune, as long as you don't hit the brakes, the converter stays locked. I even have my DFCO turned up a bit, so it cuts fuel and engine brakes (works well when taking exits).
JTW
Old 10-22-2012, 03:01 PM
ez2cdave's Avatar
JTW
Let me get this straight . . .
The 60E Tune is 100% compatible with the 4L80E transmission and the only difference between it and the 80E Tune is when. or if, the torque converter unlocks, right ?
Old 10-22-2012, 04:27 PM
Gingervitis Addict
slow67's Avatar
It's not that straight forward. The shift pattern is backwards, TCC strategy is a little different, different gear ratios, etc, so those hurdles have to be overcome.
Quick Reply: Doing my Jakes 4l80e swap soon. Anything I'm missing?
