Parts list for the TH350 swap
I found a company that will make the converter so I don't need the pilot spacer
So what else do I need or if the company makes a converter for a TH350/LS there is no need for the spacer I hear about inbetween the flex plate and crank??
If so I'm looking for a parts list for the swap for the mustang
A lot of companies (Yank, Coan, Ultimate CC) will build a converter specific to a LS1 engine so you do not need the spacer. The spacer is used to adapt the standard th350/th400 converter to the LS1 crank pilot. With a custom LS1 th350 converter you do not need this. With a standard th350 converter you do. Either converter used will need a different flex plate. This is the one I used.
http://www.summitracing.com/parts/tci-399753/overview/
Flex Plate Part No. 399753
Converter Part No. TCI-242101
Shifter Part No. 3160006
