Good stall for supercharger
It's a 2008 corvette a6 ls3 with Vortech v2-si looking to do a stall what stall speed would be the best for boost it just got a lingenfelter 2step launch ......the 60ft is killing the time
A centrifugal supercharger needs some rpm to keep it happy, so a stall converter will make a huge difference. We typically do ~3000-3500 range depending on how aggressive you want to get. Can you send me an "Ask Chris" form with all our specs and I can help spec you a custom converter. Link is in sig.
Thanks,
Chris
Thanks,
Chris
LS1Tech Sponsor
Big, I would want to be in the 32-3400 range in a triple clutch format. Prolly a 10.5" with a CNC stator in it machined for your combination!!!
Greg
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
The way I did it was, when stalling I wanted to launch closer to peak torque for better 60 foots. I looked at a ton of dyno sheets and found the centri setups making it later in the powerband
So I went 4000-4200 to get me closer to that torque of the line. It's a triple from circle D whom I highly recommend.
