Converter spacing confusion
When I look through the window on the bellhousing I see this...
I used feeler gauges and it measured out to .283
I have these spacers
and when the spacer is put on I still have this much of a gap...which reads as .245
Should I be using a thicker shim than what I currently have? On the 4l60e you want to have under 3/16ths gap or .187mm. 1/8 is about perfect.
At least none I could find...
Glad you are measuring everything carefully.
I accidentally put a little too much fluid in and it puked on my garage floor lol. When I added more it showed low but then leaked some. Drove around some more and the leaking stopped.
I just swapped out my MS3 for a F13 and the car feels way better. I can't wait to get tuned for this cam.
I have a shitty 2.73 rear end in right now and I was gonna do a 3.73 swap but after calling around for prices I don't think I want to drop $5-700 on a 10 bolt. Also from what I've read the only thing ill really Gabe is tightening up the stall from a stop.
So next up is a rearend fund lol
