A4 slipping into neutral
However, if you read up on "tuning for a stall", you will see that disabling codes is a common practice.
BTW - Congrats on getting HP Tuners. I get tremendous enjoyment out of tuning and change something nearly every day; I constantly log with my laptop. (Of course, I been an electronics/computer nerd since age 6, 52 years ago.)
Hopefully we can help you solve your trans problem.
Thanks! I've been wanting to get a copy for years. I figure I've done all the work on this car myself besides, the trans rebuild, I should be able to figure out how to tune and do diagnostics. I'm an electrical engineer by trade and a programmer so hopefully that will help out some. from what I am seeing the next thing I need for that though is to get a quality wideband setup.
Nice, I've been doing a bit of research on those. I'm not sure which one will work best for me. Where did you mount yours in the exhaust? I haven't really found anything conclusive on where is the proper location to mount a wideband.
I also found some threads detailing a way to use the old egr wires into the pcm as a way to data log with HPTuners std which will be really nice.
I have a stock O2 sensor on one side and the AEM wideband on the other side. You can even set the AEM system to "simulate" a stock narrow band, but then cannot log the wideband values. When convenient I will install another stock one near my wideband in case I ever want to try going closed-loop.
Is it effective to tune using the wide band only on one bank though? Or is the merge just too far down stream to get good readings without introducing too much latency?
I would try to avoid latency as it confuses interpretation of the logs.
