how to change the trans plug on top of the 4l60e
The transmission harness that runs from the pcm to the top of the 4l60e is very tight in there no room.I need to change out the end of that harness with a replacement plug sold on several sites.I have been under the car and can get my hand to take off the connector but I can not see how the hell you have any room to connect the new plug on the harness.Any tips??
I don't have a Gen-4 and therefore don't know if there is a clip holding the harness to the tunnel.
Perhaps your harness got pinched between the trans and the tunnel. Either that or there is a factory clip holding it. Unless the harness is mostly routed within the car and drops out above the trans.'
There are dozens of Gen-4 owners here who have removed their trans. Do any of you know the answer here?Thanks. (I know what I don't know.)
I am hoping that a Gen-4 person that has removed their own trans can explain where/how the trans sub-harness is routed.
I wish I could help more, but someone else will have to do it.
I just pulled my 4L60E in my 98 SS yesterday and that's what I saw. Hope this helps you some. I can try to get a picture later today if that's not too late for you.
Good luck.
Floyd
Good luck.
Floyd
