4l80e U Joint
Old Apr 9, 2013 | 07:35 AM
Mystery Bird's Avatar
Default 4l80e U Joint
I can't find the u joint I need to join my stock DS to the 4l80e yoke. I went to NAPA and they ordered one from their conversion chart. The end caps work but the length of the joint on the 4l80e yoke is too short. I'm tired of searching can someone please help?
I should add the 4l80e and yoke are from a 2002 GMC two wheel drive 3/4 ton truck w/6.0 engine.
Old Apr 10, 2013 | 11:24 AM
Another parts store hooked me up with the Moog 372...not even close. I can't be the only person that has had this issue.
Old Apr 10, 2013 | 12:32 PM
SSZ's Avatar
SSZ
There is a way to match the u-joint with measurements. I think you can find that through driveshaft companies like Denny's that show what measurements are required to know what you are dealing with. Hope that helps.
Here is something to work with. THere is more info on the site.
http://www.dennysdriveshaft.com/app/...iagrams/e.html
Old Apr 10, 2013 | 01:35 PM
Thanks for the link. I did take measurements but cannot find anything. The measurements refer to a S44 on the driveshaft and a 1410 on the yoke side. Guess I have to order a different yoke.
Old Apr 10, 2013 | 02:00 PM
SSZ's Avatar
SSZ
Gee, didnt think the yokes were that big on those trucks. Yeah, if nobody has a conversion joist then i think you are stuck. Try any truck or industrial shops? Even like the offroad 4x4 shops may have something.
Old Apr 10, 2013 | 10:38 PM
Smo's04Gto's Avatar
http://www.summitracing.com/search/d...350-conversion
I guess you looked at all the conversion u joints on summit?
Old Apr 11, 2013 | 02:07 AM
SSZ's Avatar
SSZ
Nice link.
Old Apr 11, 2013 | 07:17 AM
I looked so many places and asked so many people, I gave up last night and ordered a TH400 yoke. Thanks though I appreciate everyone who tried to help.
Old Jun 2, 2013 | 07:25 PM
MillsMotorvation's Avatar
Will be doing this soon, thanks for helping me on choices
Old Jun 2, 2013 | 08:24 PM
evo462's Avatar
I initially ordered a TH400 yoke for my LS1 driveshaft. However, what I didn't realize at the time was that my output shaft on the transmission was the "o-ring" style, which the TH400 yoke with splines all the way to the end would not fit on it.
I ordered mine from Jake's Performance and it fit on the output shaft perfectly. Maybe your output shaft is non o-ring'd but I'd check before you go trying to slide it on and then find it won't fit.
My 4L80e is a 1993 unit, 2WD FWIW
