What is an acceptable trans temp for built 4L80e?
I have a 11x14 B&M plate style transmission cooler sitting behind my intercooler, attached to my AC condenser/radiator, with stock fbody puller fans.
Putting down ~ 650 RWHP
I haven't had a trans temp gauge in any car of mine recently so I don't really know what "normal" would be with this configuration. Or if my sending unit is reading accurately...but I have no reason to expect otherwise.
FWIW: I run about 30' hotter when running a 3:08 (highway) rear compared to my 4:10 (strip) rear (10 converter). So if you are running a taller rear, it would explain why your temps are higher than it could be.
I guess I could always try adding a fan to the cooler to see if it helps. It's been mid-upper 80's here but will get in upper 90's this summer when I'd be driving it.
My brand new Ecoboost truck's tranny runs 192-195* all of the time... Only once have a seen 202* and that was towing 5000lbs.
I think 160-180* is perfect.
I need to log trans temp next time I get the car out but this thread gives me a idea of temps to look for.
I found a pid in my HPtuners to log the temp but I haven't tried it yet.
