Use 4L65E in 98 Fbody?!
Old Oct 31, 2013 | 05:56 PM
Camaro98Z/28's Avatar
Default Use 4L65E in 98 Fbody?!
Got a complete drop out from a 06 SSR to install in my 98 Z28. I understand the 65 is stronger than the 60. Can I use the 65 tranny? Will my 98 PCM and wiring connect to it without issues? Thanks!
Old Oct 31, 2013 | 06:03 PM
performabuilt's Avatar
LS1Tech Sponsor
Will plug right in will need to swap tail housings. The 4l65e Is only very moderately stronger than the 60e barley worth mentioning IMO.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 31, 2013 | 06:06 PM
mrvedit's Avatar
Moderator
In short Yes.
A 4L60E and 4L65E are externally and electrically identical.
However the year of the trans will matter.
An 06 likely has ISS (Input Speed Sensor), but your '98 will still have the same trans connector, just without looking at the two ISS pins. Your '98 PCM would ignore it anyway.
Around '08 the 4L60E/4L65E received an incompatible change which prevents such late-model transmissions from working with any earlier PCM.
Old Oct 31, 2013 | 06:10 PM
Thank you both.
I have a BMR tq arm relocation bracket so is it safe to assume I dont need to swap over the tail shafts?
My OEM tranny has 125k, the SSR has 40k. Seems a no brainer to use the newer lower mileage tranny if its a direct swap in since I have it right?
Old Oct 31, 2013 | 06:53 PM
mrvedit's Avatar
Moderator
Originally Posted by Camaro98Z/28
Thank you both.
Yup, a no-brainer.
Old Jan 3, 2014 | 11:45 AM
OK guys I'm actually in the process of my swap hit a little bump though.
The 65E appears to have some electronic module provision on the shifter attachment on the trans while my 60 does not.
I removed it but as you can see the rod attachment is longer, Im assuming with how the cable bolts to the trans this will cause an issue with the shifter positioning.
How do I go about changing it?
1st 2 pics is of the 65 with the 2nd pic of me pointing to what I need to swap. Last is of my factory 60
Old Jan 3, 2014 | 01:05 PM
mrvedit's Avatar
Moderator
I don't know a clean solution to your problem; perhaps/hopefully there is one.
Worst case, it is not too hard to swap the shifter shaft from your old 4L60e into the 4L65e.
Old Apr 2, 2014 | 11:30 PM
joshua1086's Avatar
Did you find a solution for this? I am having the same issue.
Is that module necessary? Do you know what it is for?
Have you ran it and did your computer have any issues controlling the 65?
Thank you for any advise you can offer!
Joshua
Old Apr 3, 2014 | 10:18 AM
I swapped out the manual shift rod between my 60 and 65 and it performed flawlessly.
Module is not needed for a Fbody car.
Old Oct 21, 2019 | 03:02 PM
Happy98ws6's Avatar
Originally Posted by mrvedit
In short Yes.
I have a 98 ws6 took out 4l60e and what to a 4l65e will it fit
Old Oct 22, 2019 | 07:05 AM
MaroonMonsterLS1's Avatar
first post on the forum
bumps a 5 year old thread
asking a question that was already answered up above in the thread...did you even read the thread?
if the 65 isn't an 08+ yes
if it is 08+ no
What's so hard about that to understand?
