4l60e alto red clutch clearance ?
Moderator
Several builders have told me to avoid the Alto Red clutches for the 3/4 clutch. Use Hi-Energy/GPZ for Blues. See my post #3 here:
https://ls1tech.com/forums/automatic...ches-4l60.html
I have posted this before, but here is is again:
Builder/member Dynamic396 has convinced me of the importance of replacing the apply plate with each rebuild, or at least measuring that it has less than .001" of coning. Replacement is good insurance for $12.
Builder/member carlsonauto convinced me that the 3/4 clutch clearance needs to be increased for Red or Blue frictions to avoid premature wear.
Also, instead of thinking overall clearance, you should think clearance per friction. From what I have been told the suggested clearance per friction are:
Hi-Energy (Brown) - .003 to .007 per friction (wet)
Performance (Red) - .004 to .007 per friction
Super-HP Blue - .005 to .008 per friction
Therefore, while the total clearance with 7 Hi-Energy friction might be as low as .025, with 8 Blue frictions the total clearance should be around .050. The Blue frictions are soft and sticky and you don't want them wearing on the steels when the clutch is NOT applied.
