4l60e aftermarket temp. sensor?
HPTuners and my pan gauge were off by about 10 degrees IIRC. In my eyes that's an acceptable margin of error between two completely different sensor makers. The stock sensor is in the valvebody which is basically in the pan so the readings should be the same.
