What converter for nitrous?
Old Feb 10, 2014 | 10:01 AM
QuickT/A's Avatar
Default What converter for nitrous?
Car is a 02 camaro SS ..
402 ls2
Heads/cam
Th400
12bolt. 3.73 gear
Weighs around 3,000
Will be getting anywhere from a 150-250 shot
Keep getting mixed opinions on all sorts of converters.
.. Yank 3600 or 3800...FTI 4000...Ptc 3600.. etc... What u guys think ?
Car will be street driven, but nothing crazy or far rides.
Old Feb 10, 2014 | 10:32 AM
DANOZ28's Avatar
from what i've read you need anti ballooning plates, i would call circle D after viewing photos of their work. cheers.
Old Feb 10, 2014 | 10:52 AM
jblankenship's Avatar
call PTC and give them your specs
Old Feb 10, 2014 | 12:30 PM
Circle-D_Brian's Avatar
We would be glad to help out the op. How often will you be spraying and how much exactly? These will be big determining factors on what we spec for you.
-Brian
Old Feb 10, 2014 | 01:07 PM
jeremyfrank14's Avatar
I have an FTI 4k lockup stall in mine. Love it
Old Feb 10, 2014 | 01:47 PM
QuickT/A's Avatar
What's your setup, if you don't mind me asking.
Old Feb 10, 2014 | 03:41 PM
408 w/ Ls3 top end, 247/255 cam, N20 outlet plate kit, 4l80e/4.10s.
Old Feb 10, 2014 | 03:42 PM
Dont think you could go wrong with any of the converter companies you have listed. I'd pick one give em a call and see what they suggest.
Old Feb 10, 2014 | 03:44 PM
QuickT/A's Avatar
probably a dumb question but will I run out of gear by the 1/4 with 4.10s with a th400 and my setup? i'll be going to a 3.73 if anything.
Old Feb 10, 2014 | 04:34 PM
that will depend on your shift point and tire size as well as rear end gear and how much you spray
Old Feb 10, 2014 | 04:59 PM
QuickT/A's Avatar
28" tire... 200+ shot . starting small (100shot) and making my way up. . Prolly won't Rev it past 7k
Old Feb 10, 2014 | 07:54 PM
BIGDRAGON's Avatar
I'm having the same questions on getting a stall for my set up. I'm going from T56 to 4L80E my car is heads and cam car spraying 150 wet nitrous, the cam is 226/234-600 112 ported 243 heads,Moser 9 with 4:11 gear and running a 28" tires the car is mostly a weekend car. Thanks for any info.
Old Feb 10, 2014 | 09:05 PM
floman's Avatar
Hey guy's
I have a very similar combo as the ones ya'll are asking about. I am running an FTI 3800 billet triple disc nitrous spec converter in my 4L85E tranny and 12 bolt with 4.11 gears and 28" tall tires. The nitrous spec converter is a little too tight for a optimized motor pass, but is very efficient and drives very well on the street and works very well with the 150 shot so far. On a motor pass I go through the traps around 6350-6400 rpms @ 123-124 mph. On my 150 shot the 4.11s are too much gear, I am on my 6800 rev limiter approx. 75 ft before the finish line in the 1/4 mile. Going through the traps @ 6800 rpms I was trapping 131.6 mph, which is just shy of what I think I need for a high 9 sec pass. I'm gonna put in some 3.73s that I have waiting on the shelf.
I just got finished ordering my next mods, Strange lightweight spool and Richmond Gear install kit. Going with the spool to insure equal traction at both wheels on the juice. The 3.73s should let me make an all out full pass on the juice.
Old Feb 10, 2014 | 10:26 PM
BIGDRAGON's Avatar
Originally Posted by floman
Hey guy's
Thanks for the info.
Old Feb 11, 2014 | 12:57 PM
QuickT/A's Avatar
Just got off the phone with Ptc and they are suggesting the 10" street/strip converter with a 3500-4000 stall on nitrous on the trans brake.. Anyone have experience with this certain converter?
Old Feb 11, 2014 | 02:05 PM
rmata's Avatar
You're cutting it close to running out of gear with your setup. I had to drop to 3.70s for the bottle. I run an FTI for my TH400. Great product
Old Feb 11, 2014 | 02:07 PM
QuickT/A's Avatar
Originally Posted by rmata
You're cutting it close to running of gear with your setup. I had to drop to 3.70s for the bottle. I run an FTI for my TH400. Great product
Which series FTI converter did you go with and what does it flash to on the juice?
Old Feb 13, 2014 | 09:40 PM
BIGDRAGON's Avatar
when a converter is too tight what does that really means? Just trying to educate myself a little.
Old Feb 14, 2014 | 05:22 AM
floman's Avatar
It means that the converter will not stall (flash) as high as what the combination really needs to get a decent launch. In other words, its not stalling up enough rpms to get the engine into the torque peak.
Old Feb 15, 2014 | 10:15 AM
QuickT/A's Avatar
Anyone running a PTC converter on nitrous?
