School me on converters please.
I was reluctant to go with a stall that high because I had a 3000 stall in my 81 PU with a TH350 and it was almost unbearable to drive at low speeds/RPMs.
The difference is amazing the only time I notice the stall at all is backing up or idling though a parking lot.
What gives?
Also, I have been advised not to manually shift my 4L60 because it can cause damage but when I shift it manually the Veh has way more power and is a lot quicker.
I have a few threads saved at home I think that have good info and I'll try to post them when I get home.
The GM 245mm core has had a lot to do with the improvements in converters available to the average consumer. When it became popular (more than 10 yrs ago) it gave converter builders a lot more options to work with over older designs. There are quite a few different stator designs alone that come in these converters from GM, before you start modifying them. Pumps come in all different fin angles, etc. It's a nice "modular" converter that you can buy a boxload of cores, cut them all apart, and have a selection of parts to build just about any converter from ranging from a 300 HP street cruiser to a 1000+ HP strip converter.
Chris
