TH400 swap parts
Old Oct 12, 2014 | 10:27 PM
SCott5's Avatar
Default TH400 swap parts
I am getting ready to swap a th400 into my camaro as soon as my turbo motor is done and wanted to make sure I wasn't missing anything for the swap.
Th400
Converter
Shifter
Crossmember
Dip stick
Drive shaft
Flexplate
Am I missing anything that I am going to need for the swap?
Old Oct 13, 2014 | 09:34 AM
NorthTexasConverter's Avatar
Yoke? Trans mount?
Old Oct 14, 2014 | 04:33 PM
fastlt1's Avatar
What do you do on a 400 swap for speedo
Old Oct 15, 2014 | 06:34 AM
lsexpress's Avatar
you pretty much got the list down
Old Oct 15, 2014 | 04:29 PM
jrpimp00's Avatar
Parts for speedo to work, if you want it
Old Oct 15, 2014 | 05:11 PM
SCott5's Avatar
Okay. Thanks guys. I'm going to search on what Speedo parts I will need
Old Oct 19, 2014 | 07:47 PM
Camaro396's Avatar
Converter pilot adapter if you're not using an LS specific th400 converter.
Old Oct 19, 2014 | 08:03 PM
jrpimp00's Avatar
GM8655291 GM Speedometer Sensor (AC Delco 213-3513)
GM8655315 GM Speedometer Drive Sensor Rotor
Pigtail to wire it in. (got mine from Oreiley's for $11)
Old Oct 19, 2014 | 09:09 PM
SCott5's Avatar
Yea I'm going to be using ls specific converter.
Thanks for part numbers. Going to walk over to advance tomorrow see if they have them
Old Oct 19, 2014 | 09:23 PM
MMorgan9812's Avatar
Thanks for this info!
Old Oct 21, 2014 | 03:00 PM
jrpimp00's Avatar
I doubt any parts store will have the sensor and/or rotor.
Jake machined me a rotor and I got my own sensor. PM me if you want the info as it wasnt from a sponsor
