what stall do i need
Old Nov 26, 2014 | 05:02 PM
billymgb1000's Avatar
Default what stall do i need
ok my car is a 1974 MGB I have a 4.8 with the gm hot cam and a turbo 350. the car only weighs 2200-2400 lbs ( depends on me and gas )lol anyways I have been driving her with no stall, since I did the cam swap I don't like it. so any help would be great. also I am running a carb no computer. I don't race her and it's a daily driver all spring and summer thanks guys and happy turkey day
Old Nov 26, 2014 | 05:12 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
not familiar enough with MGB.
what's the front to rear weight ratio ?
rear wheel drive ? what's the ratio ?
open rearend or some kind of limited slip ?
what's the 'flash' rpm' on the current convertor that's in the turbo 350 ?
Old Nov 26, 2014 | 05:42 PM
mrvedit's Avatar
Moderator
With such a light car the "flash" rpm will likely be less than the advertised stall speed.
Also, explain what you don't like since the cam swap; I think I know, but want to be sure.
Old Nov 26, 2014 | 06:41 PM
ok guys sorry about the lack of info, the weight raito is roughly 60/40 60 to front, the mgb is a rear wheel drive 2 seater convertible , I put a ford 8 inch with 279's I had 390's with the dana( mgb stock rear ) it wound to high on the highway. what I don't like about it now is when she's stopped at a red light she is jumping the cam has a good lope I love how she sounds but not how it jumps. well my wife really hates it .I kind of like looking at her when she is bouncing ( if ya know what I mean) lol. help me out guys, thanks again. the other thing I noticed with this cam was I lost my low end pull. when she hits about 3000 rpm my wheels break loose
Old Nov 26, 2014 | 06:58 PM
because of the cam,in neutral,what rpm does the engine 'like' idling at ?
sounds like you're gonna need a 'loose' convertor to eliminate the red light jumping/bouncing.
too many put in too wild of a cam without/not realizing the consequences of a OEM or equilvalent tight convertor.
Old Nov 26, 2014 | 07:22 PM
in neutral she like about 800, and can you explain what loose converter means, thanks
Old Nov 26, 2014 | 07:34 PM
I should have added a part 2 to the question.
and what is the idle dragged down to in gear at a light ?
a loose convertor will allow the engine to idle where it wants to(for lack of a better description). unfortunately it will also seems loose(slipping) above idle too.
it's probably best to contact Yank,CircleD,and/or others to get their recommendations.
https://ls1tech.com/forums/automatic...questions.html
Old Dec 1, 2014 | 08:51 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
In that combination I would recommend one of our SB series performance converters. This converter will allow it to idle in gear and also improve performance. The drivability will be great. They are also on sale for or Cyber Mon sale. Check it out on our website www.ftiperformance.com. The part # you will want is SB2800LS
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
