Need help finding Th400 VSS!
Old Dec 9, 2014 | 09:43 PM
1nverted's Avatar
Default Need help finding Th400 VSS!
car info: 02 Trans Am, lsx th400 swap
Hey guys, i have a th400 thats almost finished, i need the vehicle speed sensor that bolts to the side to complete my swap.
What i gathered from the internet and from people is that i need :
gm part # 24232618
Speedometer Drive Sensor
ac delco part # 213-3513
1988-1990 3/4 chevy pickup with a big block and a th-400. is the vehicle i was told to use as reference.
The Problem:
i have called Oreillys auto parts, Napa, Autozone, Gm dealer, All stores had a listing for a part with part numbers that i think would work however no one had any in stock or in the warehouse, Back ordered or discontinued ect...
Same thing with the gm dealer, they couldn't find any out of state either.
i have tried ebay, summit with no luck..
Also, have searched and read through ls1tech stickes/threads
Does anybody have any information on where i can get the right replacement sensor or is there a superceded part number i should be looking for?
ANY info is greatly appreciated, thanks!
Old Dec 10, 2014 | 02:33 PM
mrvedit's Avatar
Moderator
Here is the same question from over a year ago:
https://ls1tech.com/forums/automatic...sor-stock.html
According to that, check if Jake or FTI have any left, but be prepared to pay appropriately for a long discontinued and very rare part.
Old Dec 10, 2014 | 05:22 PM
jrpimp00's Avatar
Jake didnt have one when i was looking a couple of months ago. Ill pm you where i got mine since its not a sponsor
Old Dec 10, 2014 | 11:24 PM
1nverted's Avatar
jr found one! purchased!
thanks alot
Old Dec 15, 2014 | 05:56 PM
Bullit95T/A's Avatar
were did you find one at?
Old Dec 17, 2014 | 12:50 AM
AutomagicLS1's Avatar
PATC sells everything you need but this post will probably be deleted before anyone sees it lol
Old Dec 17, 2014 | 08:01 PM
mrvedit's Avatar
Moderator
The guideline is not to have links to non-sponsor websites.
Old Dec 18, 2014 | 12:51 PM
1nverted's Avatar
In that case ill post the name where i found it:
Ive been getting some pm's asking where i got it, It will be very helpful for other searching,
Oe Parts Hq
google is your friend here.
I hope this helps everyone!
These parts are becoming harder to find...
Old Dec 18, 2014 | 12:54 PM
Fullen's Avatar
I just used the speed sensors in the front wheel and changed it in my tune. Are you trying to keep ABS, or just using this considering you have the spot for it in your trans?
Old Dec 18, 2014 | 09:59 PM
1nverted's Avatar
i had no sensor at all, a big hole in my trans
