My T56 to 4L80E Build
And advice on the ears on the trans I keep hearing about?
The BCM uses that for the reverse lamps... but the PCM also uses it to select the PN or IG (in-gear) tables in the engine tune.
The pressure switches on the bottom of the VB tell the PCM which gear range is selected (P/N, R, D4, D3, manual 2, manual 1), so it knows how many and what gears to sequence thru.
The PCM uses the VSS and TPS sensors to lookup the shift tables to see what the current gear should be (and to shift into it).
I see, so thats why you said to check the pin out. We did follow them as per speartech but who knows.
Sorry for my absence. House hunting/selling was rough. Closed this week though finally
TA's gettin a garage upgrade out of this all lol 1 car to a huge 2 car. I'll be moving in Friday so hopefully soon thereafter I'll be able to start working on my own swap. Its been a long time coming and the parts have been sitting around long enough. Sorry for my absence. House hunting/selling was rough. Closed this week though finally
TA's gettin a garage upgrade out of this all lol 1 car to a huge 2 car. I'll be moving in Friday so hopefully soon thereafter I'll be able to start working on my own swap. Its been a long time coming and the parts have been sitting around long enough.Nice man thats badass you upgraded the garage space. Thats probably gonna be really nice!
Add the PN switch (and anything else that is missing, like the TCC brake switch).
Check that the correct signals are seen at the trans harness connector (need a bidir scantool).
Just started today and barely had any time before having to attend to other things. These are the steps I've written down so I can keep on track. I still need to insert things in the correct location like installing the shifter (going from T56 to 4l80e) and cable, installing my Compushift2 controller, and anything else I'm sure I'm forgetting.
Disconnect the cable from the negative battery terminal
Remove the center console (Those of you that have troubles doing this might appreciate this tip: you may notice that the center console doesnt lift up out of the way because the E-Brake handle needs to be pulled up to get the console to clear it but then the console wont lift up over it because the handle is too high. To get around this, push your drivers seat to its rearmost position, then recline the passenger seat fully. Once those are done you can lift the center console up as high as you can and then rotate the console counter clockwise (think helicopter spinning the console, not rolling the console) 90 degrees. once the console is pointed towards the doors after rotating 90 degrees you will have enough room to lift the console up over the E-Brake handle)
Remove the shift lever handle
Raise the vehicle and place it securely on jackstandsMove drainpan, rags, news papers, and wrenches under the transmission
Remove transmission drain plug at the bottom of the case and allow the lubricant to drain into the pan.
After the lubricant has drained completely, reinstall the plug and tighten it securely
Place the transmission in neutral with the parking brake off
Make reference marks on the driveshaft and the pinion flange in line with each other. This is to make sure the driveshaft is reinstalled in the same position to preserve the balance
Remove the rear universal joint bolts and clamps. Turn the driveshaft (or wheels) as necessary to bring the bolts into the most accessible position
Tape the bearing caps to the spider to prevent the caps from coming off during removal
Lower the rear of the driveshaft. Slide the front of the driveshaft out of the transmission
Wrap a plastic bag over the transmission extension housing and secure it in place with a rubber band. This will prevent loss of fluid and protect against contamination while the driveshaft is out
Support the rear axle with a jackstand
Remove the nuts and bolts that attach the forward end of the torque arm to the transmission extension housing. Note how the two brackets (inner and outer) on the left side of the extension housing and the catalytic converter hanger/torque arm bracket on the right side of the extension housing are oriented to ensure proper reassembly
Remove the nuts and bolts that attach the rear end of the torque arm to the rear axle
Remove the catalytic converter hanger assembly
Unplug the electrical connectors from the back-up light switch and the speed sensor. Remove the electrical connectors first then unscrew the sensors
The reverse lockout solenoid is located on the left side of the transmission extension housing. Unplug the electrical connector from the reverse lockout solenoid. Remove the reverse lockout housing hold-down screw and remove the reverse lockout assembly
The skip shift solenoid is located on the left side of the transmission. Unplug the electrical connector. Unscrew the skip shift solenoid
Remove the starter motor and any bell housing covers. From under the vehicle, disconnect the solenoid wire and battery cable from the terminals on the solenoid.
Remove the shield over the starter motor by unsnapping the clips and then removing the starter mounting bolts.
Remove the starter motor. Note location of the spacer shim(s) if equipped
Detach the clutch hydraulic line at the bellhousing
Support the engine assembly with a floor jack (place a block of wood on the jack head to protect the engine oil pan). Support the transmission with a transmission jack
Remove the transmission crossmember and mount.
Remove the bolts securing the bellhousing to engine. Pull the transmission and the bell housing to the rear and separate it from the engine. Lower the transmission on the jack and wheel it out from under the vehicle
Remove all old sealant from the extension housing
Spread transmission fluid on the torque converter rear hub, where the transmission front seal rides.
With the front of the transmission facing up, rotate the converter back and forth. It should drop down into the transmission front pump in stages.
To ensure that the converter is fully engaged, lay a straight edge along the transmission to engine mating surface and make sure the converter hub is at least 1 1/8 inch below the straight edge. Reinstall vice grips to hold the converter in this position. Lubricate the front hub of the converter with multipurpose grease
With the transmission secured to the transmission jack, wheel it into position, raise it up to position and connect the oil cooler lines
Turn the torque converter to line up with the holes in the driveplate
Carefully move the transmission forward until the dowel pins and the torque converter are engaged. Make sure the transmission mates with the engine with no gap. If there is a gap, make sure there are no wires or other objects pinched between the engine and transmission and also make sure the torque converter is completely engaged in the transmission front pump. Try to rotate the converter - if it doesn't rotate easily, it probably isn't fully engaged in the pump. If necessary, lower the transmission and install the converter fully.
Connect the cooler lines and tighten them securely.
Install the transmission to engine bolts and tighten them to 35 ft-lbs. As you're tightening the bolts, verify that the engine and transmission mate completely at all points. If not, find out why. Never try to force the engine and transmission together with the bolts or you'll break the transmission case.
Raise the transmission and install the transmission mount and cross member. Tighten all nuts and bolts securely.
Install the torque converter to driveplate bolts. Tighten them to 46 ft-lbs.
Remove the jacks supporting the engine and transmission
Install the dipstick tube
Reconnect all electrical connectors
Reconnect the catalytic converter hanger
Reattach the torque arm. To install the torque arm raise it into position and install the nuts and bolts. Do not tighten anything until all fasteners at both ends have been completely installed, gradually tighten them until they're all snug, then tighten everything to the torque specifications :
At transmission - nuts 30 ft-lbs, long bolts 37 ft-lbs, short bolts 20 ft-lbs
At rear axle - bolts 96 ft-lbs, nuts 97 ft-lbs.
Remove the jack supporting the rear axle
Install the driveshaft. Remove the plastic bag at the end of the transmission and wipe the area clean. Inspect the oil seal carefully.
Slide the splined front end of the driveshaft into the transmission.
Raise the rear of the driveshaft into position, checking to be sure the marks are in alignment. If not, turn the rear wheels to match the pinion flange and the driveshaft.
Remove the tape securing the bearing caps and install the clamps and bolts. Tighten to 14 ft-lbs
Check and refill the transmission with transmission fluid. Add approximately 7 pints of ATF through the filler tube.
With the transmission in park and the parking brake set, run the engine at a fast idle but don't race it.
Move the gear selector through each range and back to park. Check the fluid level. It will probably be low. Add enough fluid to bring the level up to the COLD FULL range on the dipstick.
Remove the Jack stands and lower the vehicle
Check under the vehicle for leaks during the first few trips.
