Trans Go 4L60E-3
Why not just do it the right way:
1. Purchase a 4L60E harness and pin it into your PCM connector. I think Speartech makes one for about $200 and includes the directions.
2. While you could get the PCM reflashed to switch it from M6 to A4, it is likely cheaper to buy a used PCM. I just bought several from ebay seller "spareecm" for $89 who will pre-program it at that price for your VIN, transmission type and a few other details and options.
This will give you a fully operating 4L60E, which besides being more convenient will also increase the resale value of your car when that time comes.
If you have the time and ability you could get the whole trans harness and PCM plug from a u pull it yard and use that to add all of the trans wires to the harness on your car. It’s just a matter of unpinning the wires form the junk yard PCM plug and plugging it into the same spot on your car’s PCM plug. It’s not hard just tedious. Then just have your PCM flashed.
