Jakes d3 trans brake wiring
Old Jun 18, 2015 | 03:32 PM
rpm-inc's Avatar
Default Jakes d3 trans brake wiring
This new to me 4l80e has a d3 trans brake. It requires the trans brake activation for reverse. So instead of pushing the trans brake button, I am hoping this works. Can someone please check my diagram?? Thanks!!
Old Jun 18, 2015 | 03:43 PM
jakeshoe's Avatar
The D3 transbrake requires 12V+ to activate.
Old Jun 18, 2015 | 03:45 PM
rpm-inc's Avatar
I swore I read somewhere it was ground?? hmmm. Good thing I posted, lol
Old Jun 18, 2015 | 04:10 PM
rpm-inc's Avatar
D1 requires ground? I went through jakes site again and cant find anything about 12v or ground for the d3. I am assuming with your screen name, you are affiliated with jakes performance?
Old Jun 18, 2015 | 05:30 PM
rpm-inc's Avatar
for12v+???
Old Jun 18, 2015 | 06:51 PM
GMCSIERRA5.3's Avatar
he is jake...i would call there shop for faster response
Old Jun 18, 2015 | 08:43 PM
jakeshoe's Avatar
That should work.
There are instructions on the website.
Old Jun 21, 2015 | 10:03 AM
rpm-inc's Avatar
How many amps does the switch need to be rated for?
Old Jul 19, 2015 | 01:03 PM
rpm-inc's Avatar
I was in the middle of adding the pin to the trans harness for the brake. I went out to garage to look at connector on trans to see where to put it, and there is no extra pin.....
Could this be because it had the manual control box on it before? Or is there no trans brake even installed in this thing?????
Old Jul 19, 2015 | 01:15 PM
jakeshoe's Avatar
Some early units we used a pass through connector on the passenger side, on top of the case.
Otherwise it has to pass through the main connector.
Old Jul 19, 2015 | 01:22 PM
rpm-inc's Avatar
Jake can I pm you the original owners name? Would you have a build sheet under that name?
Old Jul 19, 2015 | 02:28 PM
jakeshoe's Avatar
We should have records depending on how old it is.
Email them to the shop address.
Old Jul 19, 2015 | 02:40 PM
rpm-inc's Avatar
OK, thanks, emailing now. Should be less than 2 years old.
