Convert to 4l60e
I want to go back to automatic transmission because of this city traffic, it's a lot of stop and go, and just isn't friendly towards a standard.
Now, I have a 1995 Corvette computer, which was automatic off an LT1, and there's a few 4l60e transmissions in the area I can grab easily, which should bolt right on to this current LT1 I have.
What exactly would be required to get the 4l60e to run properly? Will the 95PCM from the vette run it no problem, or will I need to replace the entire wire harness? I also hear the trans would need an external cooler, even though the rad is setup to cool the trans already.
Edit: a local scrap yard has a 1995 3.4l v6 with the 4l60e, but they said the inside of the V6 and V8 4l60e are completely different, and it won't up to the power of the V8 - I can't confirm that or not, because I was previously told otherwise.
The only difference between a 4L60E from a V6 and a V8 is the shift firmness determined by the size of the holes in the separator plate and perhaps the accumulator springs. These are all relatively easily changed. Contrary to what your JY said, the internals are identical and the strength is identical.
Keep in mind that any trans from a JY might already be worn out or have only a few miles left on it. Since (especially the early) 4L60E has various weak spots, I would be more inclined to get a 4L60E from a V6 as it is less likely to have been abused.
I would likely install the "Vette servo" too, a $15 part. A new separator plate, drilled for a V8 (or performance V8) could easily be installed by a trans shop for about 2 hours labor, $50 in parts plus fluid and filter.
They've also got a 96 Camaro V8 computer, which should hook up no problems.
Let's say I grab this 4l60e and compatible year computer. They should in theory just bolt right up, correct? I know with the 4l80e I need a yoke, but again I've heard mixed reviews about going from T56 to 4l60e.
Found a detailed walk through on the vette servo, appreciate that little tidbit of info. I took a quick peek around for the separator plates and they mostly seem to be on ebay, any particular source to get a V8 setup?
The separator plate you want is the Transgo part # 46-96-PLT; $20 at Summit Racing. Then follow the instructions to drill it for a V8.
I guess for everyone else my question would be, is the wire harness the same between the manual and automatic? Can I hook up a manual wire harness to an automatic computer and trans? Will there be anything missing, or are there different ground wires that could fry everything?
Now, I already have a wire harness connected to the T56, albeit a 1996 wire harness. Is there any way to change this harness to control the 4l60e using the 1995 computer?
You could then use any '96 through '07 4L60E/4L65E/4L70E; later model transmissions are stronger - some improvements were made in '98 for the LS1 and more improvements in '03 for the LS2.
The trans is from a 95 camaro though. It should run it, but I'd still need a wire harness. I did find someone who has a 95 harness, however he cut off all the wires for emissions, but still has them. So as long as the base of that harness works, it should control the trans.
I should have it late this week, so ill chime in then and let you know how it goes.
My only other question though.
The car has the third pedal for the clutch. Do I have to remove that pedal to use the 4l60e + harness? Or will I still need to clutch to ignition?
The harness without emission wires should be fine. Probably more than you want to spend, but I know at least one company that could make a custom harness for around $500.
The clutch "safety switch" wiring can be moved to the trans - possibly to the shifter. The thirdgen.org forum might have better info on this.
Just for sh*ts and giggles, whats the company that can produce a harness for $500?
Turns out the fella with the harness that I thought was a mangled 95 is actually a 97, which I dont believe will work properly, if I'm correct.
