For the smartest 4l60 guy here, solve problem.
Old Jan 5, 2016 | 05:25 PM
GMPPDEALER's Avatar
Default For the smartest 4l60 guy here, solve problem.
4l60e in my 2000 rcsb with a whipple 😜. Come up to a stop sign, it turns green, u take off and it revs up about 200 rpm and then just engages. It does it in OD,D, and 2 but not in low or 1st manually. Line pressure is 65+. So what ya think a guy should look at first?
Yes fluid is good.
Old Jan 6, 2016 | 12:01 AM
clinebarger's Avatar
Is this a riddle? Stop signs don't change colors....
Old Jan 6, 2016 | 08:10 AM
GMPPDEALER's Avatar
Lights... My bad.
Old Jan 6, 2016 | 09:49 AM
bbond105's Avatar
In could be that the low roller clutch is not holding. When putting the trans in low the low/reverse clutches are applied, overriding the low roller clutch.
What is a rcsb?
Old Jan 6, 2016 | 10:37 AM
GMPPDEALER's Avatar
Regular cab short box. Well that suxs.. That's internals.
Old Jan 6, 2016 | 11:01 AM
bbond105's Avatar
If the issue stops in manual low the only thing that I can think of that changes when in manual low is that the low/reverse clutches come on and override the roller clutch. The low roller clutch is a mechanical clutch that looks something like a roller bearing but will only turn in one direction. Yes it is an internal part.
Old Jan 6, 2016 | 11:22 AM
jimmyblue's Avatar
Moderator
This sounds like a high stall speed torque converter to
me. What's the problem? That you don't (think you)
have one?
Old Jan 6, 2016 | 01:17 PM
mrvedit's Avatar
Moderator
Originally Posted by jimmyblue
This sounds like a high stall speed torque converter to me. What's the problem? That you don't (think you) have one?
I assume the OP is stating that this problem just started happening. And that "just engages" means its suddenly grabs and not a gradual process as with a high stall converter.
OP: This is why a more detailed description is needed for us to reach the most likely diagnosis.
Old Jan 6, 2016 | 01:57 PM
GMPPDEALER's Avatar
No stall. No it ls not gradual, been doing it for awhile, in drive on flat ground with the brake off it won't roll forward until u give it 2-300 rpm. Then just takes off.
Old Jan 6, 2016 | 09:45 PM
jimmyblue's Avatar
Moderator
In this case I'd begin with fluid level; last TC swap, I
got the car back with about 3 quarts short and it kind
of behaved this way. Marginal pickup at the pump.
