Should I be worried about my transmission?
Hey guys, I need the cold hard truth on this one. I have a 1997 Camaro Z28 automatic (4L60E?) with 132,000 miles on it. My question is should I be worried about my transmission going soon? Because when I am in park and I shift either to reverse or drive, the car shakes pretty violently (not terrible but starting to worry me) and takes about one second to get into gear. Now, when I drive the car the transmission is VERY smooth. (A little jerk from first to second but I've been told that these trannys were designed like this).
My motor mounts are fine because my engine doesn't move when I shift (had a friend check), so could it be the transmission mounts? or is this just my transmission getting old? Any information would be amazing. Thank you.
Yeah exactly, it's shifting harshly, not vibrating. I think maybe it could be my engine revving too high at idle so its slamming into gear maybe? I have a check engine light for an O2 sensor. Could that maybe causing it?
Just to throw this out, I'm not an expert so take anything I think of with a grain of salt.
A bad throttle position sensor can also cause a high idle.
Assuming those are the original O2 sensors, it's possible they're not working as well as they should with 133,000 miles. The various sensors can cause shifting issues, such as the MAF sensor or the air temp sensor, when they go bad. Not sure if O2 sensors affect shifting to the degree you're experiencing, or at all.
Bad stuff at the front can cause emissions issues in the back end. Maybe your O2 sensor code is actually a symptom of something wrong closer to the engine? I used to get a catalytic converter code but after changing out the (functional, no codes for it) 20yo mass airflow sensor the cat sensor efficiency code stopped coming on.
If the more experienced people think it could be a bad TPS, get the AC Delco OEM one. I got the AC Delco professional series one and it crapped out a few months later and I had to buy another one, except went with the OEM line this time.
Glad you mentioned this. Because it idles at a hair above 1000 rpm. Is this something where I should try to get a tuner to fix the idle speed? Or could it be something else? Or should I just leave it?
