1996 4L60e
Old Feb 13, 2016 | 01:05 PM
ART T's Avatar
Default 1996 4L60e
I have a 1996 LT1 and 4L60e that I am converting to OBD1. Do I need to do anything to the transmission besides changing the 3-2 downshift solenoid? Thanx
Old Feb 13, 2016 | 10:40 PM
mrvedit's Avatar
Moderator
Please be more specific about what year 4L60E you have and what PCM you are using with it.
Old Feb 14, 2016 | 07:58 AM
ART T's Avatar
The PCM is a 1995.
Old Feb 14, 2016 | 09:56 AM
mrvedit's Avatar
Moderator
Hopefully pro builder Clinebarger will chime in here, but I believe the VB hydraulics are also different and you will need to swap in a complete '95 VB to work with the '95 PCM.
This member may soon have one available because he is going the other way:
https://ls1tech.com/forums/automatic...-possible.html
And here a detailed posting by Clinebarger are differences in the early years:
https://ls1tech.com/forums/automatic...vs-2001-a.html
Old Feb 14, 2016 | 07:17 PM
clinebarger's Avatar
The best thing to do is just run a '96-'97 PCM & leave the trans alone....Barring a really good reason to run a 1 year only '95 OBD 1.5 PCM???
If your hell bent on a '95 PCM....
Swap the Valve body AND Plate for a '95 models (With a PWM 3-2 solenoid).
If you swap a PWM downshift solenoid into a "On-Off" Valve Body, Your 3-4 clutch life will be compromised, The PWM solenoid never turns 100% off, And will not allow the 3-2 Control Valve to exhaust 3rd accumulator oil into the 3-4 clutch circuit as it should during a low speed 3-2 downshift.
Old Feb 14, 2016 | 09:33 PM
mrvedit's Avatar
Moderator
Thank you for the info and explanation of what would happen if only the 3-2 downshift solenoid is swapped.
When mentioned a VB swap, I keep forgetting to say that the separator plate needs to be swapped too; thanks for pointing that out again.
Old Feb 15, 2016 | 07:33 AM
ART T's Avatar
Thanks for the info. I have a 1995 VB and I can program OBD1. Again, thanks.
Old Mar 1, 2016 | 09:44 AM
ART T's Avatar
Do I need to be concerned about the converter? PWM or non PWM.
Old Mar 1, 2016 | 01:33 PM
mrvedit's Avatar
Moderator
While GM probably made a small change to the lockup friction material when PWM was introduced, I think (correct me if I am wrong) that the difference is very minor and not worth your concern.
UPDATE: Mr Bond disagrees and has much more experience.
If the budget allows, do consider at least an entry level converter from either CircleD or FTI.
Old Mar 1, 2016 | 04:35 PM
bbond105's Avatar
I may be mistaken but I don’t think you can use a non PWM converter on a PWM trans, unless it has been converted to the on/off apply. The clutch material will not hold up to the slow apply. The PWM converter uses a woven carbon material on its clutch.
Old Mar 1, 2016 | 07:10 PM
mrvedit's Avatar
Moderator
I defer to Mr Bond's greater experience and have updated my previous thread.
Old Mar 1, 2016 | 11:34 PM
Dynamic396's Avatar
Not to gang up on you, Ted, but bbond105 is correct.
GM actually has at least three different linings that they used over the years, but if you use a converter with the woven carbon lining, you'll be good in any case. I typically use woven carbon converters and then delete the PWM in the valve body.
Old Mar 2, 2016 | 02:29 AM
ART T's Avatar
Thanks to all. I remember when building cars was much simpler!
Old Mar 2, 2016 | 08:24 PM
mrvedit's Avatar
Moderator
Glad to be corrected as my goal is technical accuracy. This is also very informative to me and probably others who don't know all the mysteries of converters.
