4l60e not shifting higher than second
Using the LT1Swap wiring diagram Circuit Numbers to the PCM, the only circuits I cannot find where they go to are 1786 (ORN/BLK - Park/Neutral Signal), 1737 (YEL - Output - Park/Neutral), and 275 (LT GRN - Output - Park)
I've looked over everything multiple times, and there aren't any wires that have been removed out of the harness, that were not called to be pulled out.
The only symptoms I have are that it does not shift from 2nd gear once it is in second. When I start it, it begins in 1st, then it will shift to 2nd. But if I come to a stop, it will not shift back down to first. and under no circumstances will it shift to 3rd or 4th. if I mash the pedal, it will not kick down a gear, either. The fluid smells fine, and looks fine. fluid level is fine as well.
Any help is appreciated. I really don't want to drop $700 on a stand alone harness. and trying to find someone who will sell just a harness is almost impossible. Even the yards don't do it.
You might have a wiring problem from pins N, P and R which allow the Manifold Pressure Switch to tell the PCM which position the shifter is in. The PCM might think you are in [D2] when you really are in [OD]. A good scanner will show that too.
These links might help you:
https://ls1tech.com/forums/automatic...lems-help.html Post #4
http://www.msgpio.com/manuals/mshift/wiring.html
