Need help please 4L60e
Old Feb 24, 2016 | 12:25 PM
Camaro70ls2's Avatar
Default Need help please 4L60e
Hi every1
I bought 6.0L LQ9 2003 of Sierra for my 70 Camaro.
Which I am converting to LS2.i have th400 and just bought 4L60e 1997 of astro van.so like to know if I want to put 4L60e on my lq9 what parts need to be replace to install the trany with the engine.please if any one can write me a list what parts will I need.I have all the swap parts from brp.
Thank you
Old Feb 25, 2016 | 07:45 AM
Plz can any one help me? Or if any one can tell on Sierra 2003 which transmission was used? Can I use that on my 70 Camaro with lq9 motor?
Old Feb 25, 2016 | 08:23 AM
mrvedit's Avatar
Moderator
First a '97 will not bolt up directly to an LS engine, but only needs a spacer and the enlargement of the holes in the flexplate. My sticky documents the details:
https://ls1tech.com/forums/automatic...s-spacers.html
My real concern is taking a nearly 20 year old trans, likely with a zillion miles, which was designed for 300HP/TQ engine and hooking it up to a 450HP+ engine. If this trans was never rebuilt, there is a good chance it will fail after just a few WOT runs, which will not only ruin the trans and the converter, but also waste a lot of your time and/or money.
GM make improvements in '98 to handle the additional power of the LS1 engine and again in '03 to handle the additional power of LS2 engines. Besides the weak 3/4 clutch, the sun shell and forward sprag are common failure points when an old 4L60E is hooked up to a powerful LSx engine.
So, I would suggest putting the '97 on CL and finding a '03 through '08 4L60E/4L65E/4L70E. Probably not what you wanted to hear, but it will save your money, effort and frustration in the not-so-distant future.
Of course, there might be other opinions too....
Old Feb 26, 2016 | 11:05 AM
Just found 4L80e silverado trany 2005 6.0L.
Like to know if it's fit directly without any mods on my 2003 6.0L lq9.
Old Feb 26, 2016 | 11:47 AM
mrvedit's Avatar
Moderator
You will need the spacer that bolts on behind the flexplate and a compatible flexplate.
There are numerous threads on the electrical harness and/or tuning changes needed for a 4L80E; many others have done it successfully without too much trouble.
Personally I think this is a better choice than the old '97 4L60E.
Since you have a '70 Camaro, are you also on nastyz28.com? The "High Tech Retrofits" section has a wealth of LSx info for Gen 1 and 2 Camaros.
Old Feb 26, 2016 | 01:26 PM
Yes I am on nastyz28 but not at high tech retrofits .
I have notice on my engine where the trany attach there is a notch and bolt on top of the engine coming out ...normally when the trany and engine attach it should be flat surface.
Old Feb 26, 2016 | 04:50 PM
mrvedit's Avatar
Moderator
Strange. The 4L80E bolts up to the LS block without a bolt at the 12 O'Clock position. The LS also does not take a bolt at the 2 O'Clock position.
We might need to see a picture if you cannot figure it out.
Old Feb 27, 2016 | 11:34 AM
mrvedit, sorry I just noticed that the bolt on top of the tranny, at 12 O'clock is actually just a piece of the previous tranny broken.. my error.
I just picked up a transmission/flexplate off a 2005 Silverado.
Just a question, when I had bought my motor, it didnt come with the torque converter but just a flex plate, the flex plate that came originally with the motor has 3 bolts for the torque converter, whereas the torque converter/flex plate that came with the 4L80E that I just bought has 6 bolts for the flex/torque converter.
Just wondering why would it be different? I guess the new tranny and the stuff will bolt right up, but why is it the the flexplate that came with the motor has different bolt?
Old Feb 27, 2016 | 04:37 PM
mrvedit's Avatar
Moderator
I figured the extra bolt was a "piece of the previous tranny broken" but didn't know how to say that politely.
The 4L60E and 4L80E have different bolt pattern diameters. While all 4L60E converters have 3 bolts, I believe some/most/all 4L80E converters have 6 bolts.
Old Feb 27, 2016 | 09:12 PM
So do you think that the trany and motor will attach together without any problem?
Old Feb 28, 2016 | 10:46 AM
mrvedit's Avatar
Moderator
Yes, 4L80E bolt right up to a LS engine. You just need the correct flexplate and the GM spacer.
Old Feb 28, 2016 | 11:37 AM
I think this flex plate already has spacer here are some pic if you can tell me that it's correct trany and pieces.
Old Feb 28, 2016 | 04:23 PM
mrvedit's Avatar
Moderator
I didn't know such flexplate with built-in spacer existed, but it looks promising as long as the outer gear is dished toward the front of the engine so that the starter engages properly. However, I don't know much about the various flexplates.
Hopefully CircleD or someone else can give us all more insight on this.
Old Feb 28, 2016 | 07:42 PM
thanks alot mrvedit try to put the trany and motor together hope it will work good.
Old Feb 28, 2016 | 08:33 PM
clinebarger's Avatar
That is the correct spacer & flexplate, The spacer will stick to the flexplate.
That trans looks to be out of a Chevy W4500/Isuzu NPR medium duty cab & chassis. Parking brake, Rollerized extension housing? Not a Silverado.
Old Feb 28, 2016 | 09:52 PM
To be honest don't know from where it came out from but the guy said it's from silverado 2005 ...u think its good and will work with the engine without any mods? I give the wire harness ,and ecu to a company to upgrade so he will program and fix every thing u think its 4l80e and will work perfect?
