Rookie 4l60e rebuild
#262
I would for sure put the epc screen in there. That solenoid is finnickey enough as is.
Its not going to kill the trans by leaving them out. They're they just to protect the life of the solenoid. It's not like they're a flow restriction or anything so I always use them.
#263
Transmission should be going in this Saturday
#264
https://www.ebay.com/itm/Pressure-tr...53.m1438.l2649
If you have hp tuners, this is a great sensor to invest the $20 in.
I personally have used this sensor and wired it using the fuel tank pressure input to the ecu, just turn the codes off for it. You can log line pressure and then go back and see what it's doing during a shift, or under different conditions. I just leave mine in the pressure port and look at it whenever I want to get the laptop out and log.
#265
****Transmission is complete and will be going in this Saturday so here is a to date review of the past 3 rebuilds. Last two done by me and documented in this thread, original rebuild done by a shop.****
Original (shop)
- Original build (shop) installed sonnax performance pack.
- sonnax 2-3 shift valve
- Sonnax input drum reinforcement sleeve
- TransGo separator plate with all feed holes and band release drilled to .093"
*Issues*
- Band clearance was set at .250"
- servo release check valve installed, no 3rd accumulator capsule, solid plug in that bore.
- cracked forward apply piston is what let loose
My First Rebuild
- full rebuild with all new clutches, steels, some bushings & all new seals and gaskets.
- set 3-4 clutch pack to about .030"
*additions*
- Sonnax billet forward apply piston
- Borg Warner forward sprag
*Issues*
- installed 3rd accumulator capsule, left the solid plug in exhaust bore, reinstalled servo release check valve.
- installed new reverse input drum ( or so I thought ) rookie mistake and that drum was also turned so welded the tip of the apply pin to get band clearance around .100"
TRANSMISSION RAN FLAWLESS AFTER REBUILD
2nd Rebuild
- full rebuild with all new clutches. No new steels
- some new seals. No new bushings
- 3-4 clutch pack set at .040"
- band clearance. 060"
*additions*
Drum & servo
- ended up getting a BRAND NEW reverse input drum from TRUTECH
- sonnax apply pin
- sonnax alto wide band.
- band clearance .060"
Input Drum
- new input drum ( blew the snap ring out of the old one.
- swapped out #7 3-4 apply ring for a 700R4 #4
- reinforcement sleeve, thread lock when pressing shaft into input drum.
- new teflon seals
- 3-4 clearance .040"
- transgo springs in the 3-4 and forward cages (half the transgo springs were used in each cage)
valve body
- sonnax forward and reverse abuse valves
- sonnax end plugs
- blocked the 3-2 shift valve and the 3-2 control valve inboard
separator plate
2nd apply .093"
3rd apply .125"
4th apply .125"
band release .093"
- transgo hardened pump rings added along with new vanes
*issues*
- removed servo release valve and left it out
- removed plug in 3rd accumulator/ installed new capsule
** I have always had a part throttle bump on the 2-3 shift and am hoping getting rid of the plug and release valve clears that up **
- reason for this rebuild was blowing the 3-4 snap ring out of the input drum
- only clutches that showed any wear were the 3-4 clutches (.007" per clutch)
Original (shop)
*Issues*
My First Rebuild
*additions*
*Issues*
2nd Rebuild
*additions*
Drum & servo
- sonnax apply pin
Input Drum
- new teflon seals
valve body
- sonnax end plugs
separator plate
2nd apply .093"
3rd apply .125"
4th apply .125"
band release .093"
*issues*
#268
#270
When left in drive it just barley nips the lef limiter on the 2-3 shift. When in 3rd at wot it will hit the limiter 2 times on the 2-3 shift. No flare, just not timed perfect.
question being, is this something I should fix with a tune or something I should adjust/ mod to the separater plate ect. ?
#271
#272
#275
definitely not flare.
things I changed that might have effected it......?
- 3rd apply .125"
- removed sonnax servo release check valve
- higher stall
- #4 apply ring and about .010" looser 3-4 clutch clearance.
definitely hope it's tune related
#277
#278
It is taller...which takes away from the total real estate for the 3/4 clutches. I was just curious why you used the taller apply ring with thin clutches (you mentioned .065 clutched above) instead of just using thicker clutches to take up the clearance. Thicker clutches handle more abuse, particularly from heat.
I'm able to get 8x.080 clutches in a stack and always use the #7 apply ring.
Not saying your setup isn't going to work. I was just curious to the reasoning.
#279
I struggled to comprehend how it would work but I guess in the end I took it as I will have the same clutch space but the pack will start to engage that much sooner.
it was just something I came across in a thread while researching 3/4 clutch pack and input drum mods
