what is needed for a LS1 torque convertor upgrade
I used to have a 94 LT1 TA A4, which had a 2800 stall TC & 373's, from oem 273's. I had a Hyper tech power programmer for changing the gears. The higher stall did not require any programer change. That car is gone, due to ongoing opti headaches. So now.....
I have a 2000 LS1 TA A4 that I am wanting to upgrade the torque convertor. Also, would it be acceptable to keep the rear gears the same, although I am changing the stall ?
I also have a 2002 LS1 M6 TA. A4 is not as fun, yet. I think once a higher stall is added, it will be.
All that's needed is the converter and fluid. While you have the transmission dropped to put in the new converter, I would reccommend a short list of things to do "while you're at it".
I'd install an sfi approved flexplate along with all new hardware. It's cheap, and i've seen more than one broken flexplate cause horrible sounds that people typically attribute to a spun rod. Also, since it will be easy to get to, i'd install a .500 boost valve. This will raise line pressures across the board and help with shift firmness and holding power without the need for any computer mods. Its also cheap and very easy. Then, obviously do a new filter service before you put it back together.
Since you have the driveshaft out, u joints are also cheap and now would be a good time to do them.
I'm the type of guy that likes to tear things apart once and kill 2 (or more) birds with one stone. so none of this is NEEDED but it's all good stuff to do while you have it apart and can access it easily.
Computer tuning may not be strictly necessary, but it can get your tranny to perform optimally to your tastes. Things like shift points, shift times, lock-up points can be tuned to get your tranny feeling "just right" for you.
5 minutes into the first test drive it went into limp mode due to false misfire detection caused by a smaller diameter converter.
I tuned the misfire tables with hp tuners.
Stock flexplate, stock driveshaft, original u-joints, trans cooler and gauge.
It ran 11.8 back then, with just my own tuning and full exhaust to stock tail pipes and 8" slicks, stock 3.23's.
It now has 115k on it and same old flexplate, u-joints, etc. Will burn the street tires through 3rd. My third circuit in the trans is modified beyond what most people do. Has regular 3-4 8 plate set up.
I do not plan on any other mods or upgrades, and the car is a Daily driver, should I go higher on the stall ?
do a search and you'll find multiple write ups on where to put one. plenty of room in front of the ac condensor, others hide one in the hole where the AIR pump goes. To each their own.
Monster and RevGGTO said it best. Aside from the cooler and probably a tune, the rest is optional but it is always a good idea.
As for converter swap Im sure there's plenty of members here who didn't have access to a lift that can chime in about their experiences pulling the tranny on there back.
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Just like a few others, I'm a "while I'm at it" person, so I'd suggest a new flexpate, big cooler with braided lines, deep pan w/ drain plug, and filter at least. Depending on your budget, you can get a better torque arm w/ relocation cross member.
Was the 2600 a typo?
I have discussed this issue with many people and read much info, here and elsewhere. Not that I don't appreciate your opinion on this, but what is wrong with a 2600 TC ?
The stock converter is a very tight 1800. Going to a 2600 imo is not worth it period. With that said I think 3.73's and a 2600 vs a coyote will be a very close race.
Now if you were to do 3.73's and a yank ss3600 or ss4000 with a good radial it will still drive like stock with the 3.73's and you will have no problem rolling up a stock coyote.
The mentioned Yank SS3600 is a very tight converter in street driving. I'm pretty conservative in stall speeds, but will definitely say that 2600 is too low. A 3600 with a 3.73 rear is a very conservative setup.
What brand converter are you looking at?
To realize any significant gains from a gear swap once you have a 3500+ stall speed in place, you'd have to consider 4.10 ratio or higher (and some serious tires to match.)
A 3600 stall and the stock 3.23s would be a much, much better choice.
Furthermore, I wouldn't worry about the flexplate with a 2000 model year for the driving purpose you have outlined above. '98-'00 received a much better stock flexplate than '01+.
As for tuning, the '01+ PCM is more sensitive to higher stall speeds, and there are sometimes issues with those that don't usually occur with the earlier models. The only issue I've ever had with the '98-'00 cars is a slight idle surge (due to unloading the engine at idle) with a higher stall speed and stock tuning.
