Trans cooler between radiator and condenser
Old Jun 26, 2016 | 08:30 PM
rybern's Avatar
Default Trans cooler between radiator and condenser
I have a SSRA installed. There seems to be about 1" between the condenser and radiator which would allow mounting of a large (but thin) tube and fin trans cooler. Looking at the Hayden 679. There must reasons that folks are not doing this but I cannot seem to find much into about doing this.
Your thoughts please.
Old Jun 26, 2016 | 08:44 PM
01ssreda4's Avatar
Wouldnt hurt I dont guess if you can make it fit properly.
Old Jun 26, 2016 | 08:48 PM
98CayenneT/A's Avatar
I would skip the fin and tube and get a stacker type cooler.
To put the cooler between the radiator and condenser would not get much air flow and on top of that would act as a heater being it would be between a hot radiator and a hot AC condenser, just my thought
Old Jun 26, 2016 | 09:02 PM
rybern's Avatar
Hmmm, I didn't think about the idea of it being between two heaters. I can fit a B&M 70264 in front of my condenser on the bottom drive side corner but the 70264 is pretty small. I want my fans pulling air through it so no dope style for me. This is a weekend street cruiser with a small amount of time at the drag strip.
Old Jun 26, 2016 | 09:07 PM
The B&M 70264 stacker cooler should cool better than any fin & tube
Old Jun 26, 2016 | 09:38 PM
rybern's Avatar
I appreciate the advice. I see a 70264 in my future. I don't don any extended beating on my car.
Old Jun 26, 2016 | 09:42 PM
Majestic9C1's Avatar
mine is mounted below the passenger side headlight dope style (horizontally) and its worked very well so far
Old Jun 28, 2016 | 04:36 PM
LS6427's Avatar
Worst possible place you can put a cooler. You will create a huge hot spot on the radiator...and you WILL run hot.
Put it here....this is the best place to mount a cooler. This allows no hot spot on the condensor......it allows ambient air BEHIND the cooler to mix with the hot air coming off the cooler before it goes through the condensor. My coolant temps stayed the same after doing this.
Post #5......https://ls1tech.com/forums/general-m...g-success.html
Old Jun 28, 2016 | 07:03 PM
senicalj4579's Avatar
I agree. That's a terrible location.
Also I don't believe the hype of stacked plate being better than fin and tube. Iv had tons of practice with trans coolers and the fin and tube always worked out better.
Old Jun 29, 2016 | 02:56 AM
rybern's Avatar
Wow. I'm totally in agreement about between the condenser and radiator being a bad place now. I'm still researching trans coolers and locations.
But now I see another fix that I desparately need to fix... PS cooler. I have a PS leak and I will be deleting the silly pipe cooler and add a PS cooler. I made it to page 11 on the above thread and I'm totally sold. I'll take a close look at my fluids.
Thanks for everyone's input and advice.
Old Jun 29, 2016 | 03:32 PM
psychosid30's Avatar
Just make sure to mount the PS cooler far enough to the side to leave room for mounting your Tranny cooler later then!
Old Jun 29, 2016 | 06:58 PM
JOHNNY59's Avatar
here's were I put the trans cooler on my 98 SS. It gets good air flow due to the air dam pushing the air upwards.
Attached Thumbnails Trans cooler between radiator and condenser-dscn3266.jpg
Old Jun 29, 2016 | 10:18 PM
^^ thats where mine is located as well
Old Jun 30, 2016 | 03:30 PM
rybern's Avatar
I plan to mount my PS cooler behind the air dam.
That seems to be a popular place to mount it.
I appreciate the input.
Old Jun 30, 2016 | 10:06 PM
LS6427's Avatar
Same thing....look at my post #5...in here: https://ls1tech.com/forums/general-m...g-success.html
.........the picture on the left is my PS Fluid cooler. I also took a razor and made a cut out in my air dam so the cooler gets continuous ram air cooling. No matter how hard I drive my car in 100*F weather.......I have never seen my PS fluid temp that is entering my cooler more than 120*F......It works great.
Old Jul 2, 2016 | 03:27 PM
mjs1012's Avatar
I used to think like you too Joe, but after I put my new cooler and braided lines in, I have seen a noticeable difference in cooling. I've had both located in the exact same spot fwiw.
