4l60e problems
Ryan33 is online now Report Post
You repeatedly had the cooler line come off - how much fluid did you have to add each time? Running a trans a few quarts low will quickly damage it. This sounds like the source of your problems, not the tune.
Sometime the sprag will hold enough to allow very easy acceleration staring in [OD], but often not.
Any heavy acceleration starting in D1 will quickly destroy the overrun clutch.
In [D1] (and obviously 1st gear) the load is split between the sprag and the overrun clutch.
In [D3] the overrun clutch is only applied in 3rd gear and not in 1st nor 2nd.
In [OD] the overrun clutch is never applied, but the forward sprag is not used in 4th gear.
This is why you can manually shift from [D1] through [OD] even with a completely broken sprag.
HOWEVER if you install the Sonnax HD 2-3 shift valve, the overrun clutch is applied for all gears in [D1] through [D3]. Because this reduces the load on the sprag, it is highly recommended for high performance builds.
Now would also be a good time to go to -AN fittings and braided steel lines. Much cleaner setup and you don't have to worry about dealing with lines blowing off again.
