Built 4L60E Fluid Question
So a few months ago I had an reverse sprag give in my FLT Level5 4L60E w/ Yank 3600 and a local transmission shop rebuilt it and now it really seems like it has a whine coming from it like a gear whine. But while this "transmission shop" was reinstalling everything they took a 1/2" impact to the pinion yoke nut and went until it wouldn't go anymore in his exact words, never torqued it. Well that trashed the rear bearing.
Question is there any fluids people like better than others that might quiet things in the transmission? Amsoil, Redline, or something else?
Also if it matters since all this rebuilding stuff I haven't put 20 miles on it so maybe there's a break-in period?
Thanks Everyone
Thanks Everyone
I broke mine in for a few hundred miles taking it easy, that's if the clutches/band was replaced. Then change fluid sometime after that. I just use generic dex/merc blend.
If you don't mind I know you answer a lot of drivetrain questions for everyone but also when fixing the 12 bolt a set of new Richmond gears were added and even after setting them a couple different times they are noisy which I get Richmond's are naturally noisy but also is there a break-in period? Also my Eaton Diff seems to be locking pretty noticeably parking lot jump especially in reverse turning so probably could use a bit more Friction Modifier but do you have any recommendation on a fluid? I was looking into something like Redline Oils shockproof oils or maybe something from Amsoil to help quiet the rear down.
Get a dial type inch pound torque wrench and check the pinion bearing preload.
I picked the car up from the transmission shop and actually turned around it was so bad in rearend bearing noise. He said he never torques them goes until it won't anymore. Drove it straight over to another shop and replaced the bearings. So all that is taken care the rear noise is gone minus a bit of ring and pinion whining from the Richmonds.
Theres a problem if you need a particular fluid to get rid of transmission noise.
It's either the rear gears or something wrong.
The best thing to do would be to get the car off the ground, check the pinion preload, check the backlash, check the contact pattern. If theres no problem there put regular gear oil in it and follow the manufacturers break in instructions.
When it's done with break in put some gear oil in it with two 4 ounce bottles of ford friction modifier and deal with it. They're Richmond gears. I've heard they are more noisy for over 20 years, I tend to believe it.
Guess I touched on the wrong point.
Thanks but after looking around I know I'm beating a dead horse topic here as I'm not the first with these questions but over the years maybe owners have more insight on these topics.
I had a used factory 3.42 R & P installed, and some time later, my friend had new 3.73 Richmonds put in. Same tech installed both. Mine are silent, his are noisy.
And, as was stated above, there's no reason a newly rebuilt tranny should be making noise as long as it's full of fluid - other than a mechanical problem.
So I thought I would look at the current tune and compare it with what was in the car efore I had the transmission fixed, I noticed a few changes with the current transmission tune over what was in the car before shop repairs.
Force Motor is different - Now higher except at 0 and 100, at 100 now says -1,025
Normal Shift Pressure are negative now and Performance stayed the same
Shift Multipler is now at all Zeros
TCC Duty Cycle Maximum now vari from -1 to -4 and now minimum is changed a bunch was ay 98 now only at 7 to 21
Abuse Mode is now Enable was disabled before was disabled
Torque Reduction was at Zero before now it's not
Not sure if anything here is of concern but will post new file.
Thanks Everyone
Thanks Everyone
The part about running the pinion nut down till it won't move anymore makes me heated. Whoever that idiot is, needs a thorough beating. No, an inch pound gauge isn't really necessary as it can be done by feel.....but running it till the impact won't move anymore.....ASININE. Wait a minute, you said "pinion". You talking about the rear end....or transmission??
How do you like the 4.10s overall? What did you have before in? I had a few people trying to talk me into 4.10s but decided to leave the 3.73s as my car will almost always see only the street.
Ive had 323, 373, 410. I went to the 410 bc I run a 28" at the drag strip. Overall very little difference driving around town (with a 26.5") except it pulls better at low rpm.
