4l80e
Old Dec 14, 2016 | 02:15 PM
sbf's Avatar
sbf
Default 4l80e
At what hp level does the 4l80e have shift problems.I've heard with high hp 1-2 shift will not work
Old Dec 14, 2016 | 03:56 PM
JoeNova's Avatar
Restricted User
Are we talking bone stock 80e with no shift kit or anything?
Old Dec 14, 2016 | 04:04 PM
sbf's Avatar
sbf
no a built tranny with shift kit,transbrake auto valve body factory ecm controled
Old Dec 14, 2016 | 04:14 PM
dw456post's Avatar
Whats high hp?
Old Dec 14, 2016 | 05:19 PM
sbf's Avatar
sbf
probably around 1200 flywheel hp.my plans are to build a 408 ported 317 heads fast intake billet s485 or s488
Old Dec 14, 2016 | 05:41 PM
JoeNova's Avatar
Restricted User
Why do you think that a built 80e would suddenly stop shifting?
I'm pretty confused as to your reasoning.
There are 2000 HP cars running the 80e. The first three gears are basically the same as a TH400.
Old Dec 14, 2016 | 05:56 PM
sbf's Avatar
sbf
i have seen a few threads about the 80e not shifting 1-2 at high horsepower with auto valve body,im just making sure before i build one
Old Dec 15, 2016 | 10:08 PM
Nathaninwa's Avatar
I had zero issues with any shifts besides my own programming with a D3 valve body and I'm just under 1100whp. Not that I could put that boost through it in first gear, but at 12psi I bet it's easily 700 to 800whp on the 1-2 shift
Old Dec 28, 2016 | 05:33 PM
sbf's Avatar
sbf
why are you taking the 80e out
Old Dec 29, 2016 | 08:46 AM
Nathaninwa's Avatar
My car isn't the street car that I thought it was going to be. So I'm taking advantage of some weight savings, and the new 1 st gear ratio the glide will give me. I was launch limited on both rpm and boost, if I left with to much it would be wheels up, and if I wasn't shifting by the tree I could hit the rev limiter in first gear
