4l80e swap help
Old Dec 27, 2016 | 11:10 PM
Camaro70ls2's Avatar
Default 4l80e swap help
I did LS swap in my 73 camaro I installed 2006 4L80e from truck .now I am having problem with yoke it's too big.so I like to know can I put any thin yoke .my car had original 400th turbo transmission.here is the picture of both yoke. On the left its 400th yoke and on right from medium truck.but the big yoke won't go between the tunnel cuz it's big.so like to know what model of yoke can I buy to install with original drive shaft.
Old Dec 28, 2016 | 08:09 AM
wht/73's Avatar
It won't fit in the 80e or it's too long?
They use the same yoke.
Old Dec 28, 2016 | 08:14 AM
JoeNova's Avatar
Restricted User
Use the TH400 yoke.
Old Dec 28, 2016 | 12:17 PM
Nathaninwa's Avatar
Like JoeNova said, use the 400 yoke. That thing on the other one is a dampener the manufacture would put on
Old Dec 28, 2016 | 08:34 PM
It won't fit cuz 400 has thicker dia from outside and short. the 4l80e has thinner outer dia and it's long.so like to know what should I do now?
Old Dec 28, 2016 | 08:46 PM
wht/73's Avatar
I'm having my drive shaft shortened as we speak and the yoke that was given to me from the guy that rebuilt the trans gave me the 400 yoke.
Maybe you have the wrong yoke or seal in the trans not letting it go in.
Old Dec 28, 2016 | 09:54 PM
Nathaninwa's Avatar
Just asking, you sure it's an 80e? Does the tranny have 32 splines? Was there an option for a smaller spline count in some applications? I know the 80e pretty much only came from 3/4 and more tom trucks, so should have the 32 spline count shaft
Old Dec 28, 2016 | 10:11 PM
Yes it's 4l80e 32 spline from 2006 Isuzu NPR
Old Dec 28, 2016 | 10:24 PM
here are the pictures
Old Dec 29, 2016 | 07:39 AM
JoeNova's Avatar
Restricted User
I'm still wondering why you haven't just used the TH400 yoke.
They're interchangeable. Most aftermarket companies now sell the yokes as a TH400/4L80e yoke.
Old Dec 29, 2016 | 07:44 AM
wht/73's Avatar
Yeah me too.
I took the drum brake off my sons 80e core and put my 400 yoke on it to spin it over.
Old Dec 29, 2016 | 07:48 AM
wht/73's Avatar
Does your trans look like this?
Old Dec 29, 2016 | 08:41 AM
Nathaninwa's Avatar
Yea, the drum brake. Makes since being in the izusu. My tailhousing looks a bit different. This might be a simple tail swap and the 400 yoke will work
Old Dec 29, 2016 | 09:22 AM
my transmission look like this but it doesn't have drum brake .I will try to put back again if it's fit or not.i hope it will lol.dont you think if it fits it won't leak the oil from yoke cuz it's short?
Old Dec 29, 2016 | 09:55 AM
Nathaninwa's Avatar
Was it 4wd ? Or just missing the brake. Something used to bolt to that
Old Dec 29, 2016 | 10:22 AM
It's for 2wd .that's true it look like there was a brake there before.does the brake comes in 2wd?
Old Dec 29, 2016 | 10:37 AM
Nathaninwa's Avatar
Big trucks did like the NPR, maybe even motorhomes
Old Dec 29, 2016 | 11:13 AM
wht/73's Avatar
The picture I posted of the trans is from a 1 ton rack body chevy.
Yes its missing whats in my pic.
