700R4 TV Cable Hook Up
You still need to hook the (formally) TV cable up but it's just for shift points.
Sorry it doesn't answer your question directly tho.
https://www.summitracing.com/parts/t...-kzhoCmBTw_wcB
TV made EZ kit
The main downside is you have to use a first generation cable throttle body with the little half-circle on the back side. It's easy to tell the difference between the two.
I'm using this kit on my 6.0 install in my 84 Trans Am.
Took maybe 4 minutes.
incorrectly set will give you poor pressures and burn up the clutches in the transmission.
in 1993 they changed the nomenclature from 700r4 to 4l60. In 1994 they transitioned to the electronically controlled **** and renamed it a 4l60e.
It's otherwise nearly identically as far as hard parts inside. Even the newer 4l65e and 4l70e is basically the same internally. Just a few minor changes with planetaries and some other parts but that's it.
Thank you for the explanation. Since the 4l60e is electronic, there is no TV cable?
