4L60E at high rpm?
I was thinking about this as well. I'm wondering if my combo makes enough power to run a glide. Peak power is at 7500 rpm, peak torque is at 6400 rpm. Will need to be shift at 8000+ rpm.
Why not a 4L80E?
Yes it's heavier but as you mentioned , my car dead hooks (at the track) and hits the DR's hard and doesn't need the 3.06 1st gear to get it out of the hole and the ratios are only .04 off the 350 it replaced.
And if I leave it in D3 or lower, when messing around on the street or making a pass it "should" be ok as it's partially a 400 which is stronger then the 350 I've been beating on for the last 15yrs.
That was a stock rebld with a shift kit.
Can you build me one?
It is always greatly appreciated when he posts his knowledge and "secrets" here.
Despite being a fan of the 4L60E/4L65E/4L70E for cars even in the 500-650 HP range, I would recommend a 4L80E above 650HP and recommend that for you.
For one a top-level 4L60E will all the billet parts and the mentioned 6-pinion front planet is going to cost $5000 and still won't be as strong as a moderately build 4L80E.
