Wiring in a manual switch for TCC on a 4l80e
Do use have HP-Tuners or a data capable scan tool?.....This is alot easier than hacking up your wiring & trying to fool the PCM. What is the TCC PWM commanded Duty Cycle when the converter clutch is enabled?
Some "Segments" do not "Take" to the PCM, Did you match the OS numbers?
The TCC PWM Solenoid uses 2nd Clutch Oil to control the TCC Regulator Valve, I would check the external control circuit with a new Solenoid & internal harness already in place.....
Make sure Pin #2 (brown wire) of the Red PCM Connector is wired to Pin "S" of the transmission connector, This is the TCC PWM Solenoid control circuit.
Using a digital volt meter, Hook the red lead to Pin #2, Hook the Black/Common lead to a good ground. I would remove the terminal from the cavity at the PCM, Strip back a 1/4" section of insulation about 2" from the terminal, Slip on a piece of 1/8" heat shrink over the wire, Leave it loose for now....You can heat it in place after the diagnostics.
The objective is to watch line voltage on the circuit.......The "High's"...Around 12vdc when the solenoid is commanded "off/venting" (Un-locked).
And the "Low's"....Zero Volts when the solenoid is commanded "on/closed" (TCC locked)
The variable here is the possibility that the circuit is getting dragged low by a intermittent short to ground in the harness between the trans & PCM.
Set all the "Release TPS" tables to 100% across the board, The tabs are highlighted in red, I have never seen these tables....Stock or Tuned have the values you have in your tune.
Changing certain tables on certain PCM's can cause wacky things to happen, To tell you the truth.......I don't really know what the TPS Release tables do that can't be done in the Apply/Release Tables.
I have my Apply/Release tables set to not lock the TCC above 50% TPS & Will unlock the TCC if I exceed 50% TPS even though my TPS Release Tables are maxed out.
Your Normal TPS Release Table.....
My Normal TPS Release Table.....
