4l60e won’t shift 2-3 WOT
The trans was serviced about 2000 miles ago... did oem solenoids harness etc.... deep pan and cooler. Checked the fluid, full and still looks new.
Never had any issues till about 100 miles ago.
Tried changing shift speed/rpm and it did nothing.
Thanks in advance.
Thanks in advance.
Set your max speed to 248 and your min to 247.
Set your WOT shift rpm to 6000 (or whatever rpm you like).
See if it shifts then.
This will command the shift at rpm vs speed & rpm.
