TH400 w/ UltraBell - Texas Speed headers - Clearance issues?
hey guys very happy to announce I have ordered all the parts for my Th400 swap on my 2002 Camaro. Ordered almost everything from FTI... they were absolutely outstanding. FTI has earned all of my transmission related business from now on. Bought the new trans crossmember torque arm and rear suspension from MWC.
Discussing with my buddy on installing it all when it shows up ... we realize this is basically a simple bolt in operation, measure driveshaft, tune 4L60 codes out of pcm and roll... only two questions We came up with when talking about it today..
1. Anyone have Texas speed headers and do this swap with the ultra bell? Any clearance issues with this combo?
2. How do I get my VSS input to function again. I did find the option of using wheel speed sensors in front, problem here is my new Strange front drag brake kit deletes those, and my S60 rear was ordered with no ABS/Tcs provisions. Anyone have any input?
Thanks in advance.
Thanks in advance.
no clearence issues hear. tsp headers fit verry well with my ultra bell housing. the clearence issue i had with my tsp headers were more with hitting part of the k member on pass side. nothing a grinder cant take care of. theres plenty of meat on the kmember to remove
I didn't have any issues with my tsp headers and the stock housing. I too went with FTI for everything needed to swap to a th400. What converter did you go with? I couldn't be happier with my set up
FTI?
http://ftiperformance.com/Speedo-Rel...400-FSPXXR.htm
The 40 tooth and whatever year truck had the sensor for it. Late 80's early 90's truck.
Good to hear. Thanks a lot. Tubular k member for me. Tons of room now!!
FTI was awesome. My invoice shows a 9" billet converter anti balloon plates Cnc stator triple bearing and billet cover. Told them I'd like to leave line on two step and trans brake at around 3800-4000.
Damn that's awesome. Didn't know it was an option. I'll call them back tomorrow and see if it's not too late to tack that on to my order. Thanks for the responses guys.
FTI?
Hey guys, love seeing all the FTI 400 swap builds!!!
we have those reluctors in stock! I have found the hard part of getting the VSS to work is finding a WORKING sensor. They have been hard to find for some time, and are expensive when you do find them...
I do know that there was user on here that said he found a VSS for another vehicle that he was able to make work with a few extra steps in HPT. Hopefully he will see this thread and chime in with his results on if it worked.
Another option I see guys use is a mechanical speedo on the transmission with a mechanical to electrical speed sensor adapter.
-Dalton
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
Did a little digging for the speed sensor and found a thread on yellow bullet that pointed to this http://www.oehq.com/oeparts_213-3513_acd.htm . Took that number and googled it and it come up with a bunch of hits that show a sensor that crosses via part number, and looks the same, but claims it is for a 4 speed. For 26 bucks from rock auto or probably from your local jobber might be worth a shot unless someone can confirm it's incorrect.
Just got done doing a little digging back in our transmission department. i have 2-3 of these sensors off of some cores we tore down. If you guys are interested give me a call here at the shop or shoot me a PM!
386-736-5816
-Dalton
386-736-5816
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
1-866-726-8358
FTIPerformance.com
I'm not doing a TH400 swap, but It might be worth the attempt by someone who is. Even if ALLBLACKEDOUT5 got one from FTI and used it to get his set up working then snag one from your local parts place and toss it on to see. Might make the whole unicorn feeling of this sensor go away.
Standard Motor Products part #SC89 seems to be a good aftermarket part # for a 3 speed auto speed sensor from a 90 c1500. My local Auto Plus has 3 in stock for $23.21
Thanks for all of the posts guys, I wanted to say thanks to FTI again for helping me. Before checking back to this thread I called today and tacked on the 40 tooth reluctor wheel to my order, they didn't even charge me... These guys really care about customer service. Then I signed on here and saw another rep from FTI said they had a couple sensors, so a few short minutes later I again called these poor guys back and they in fact have a few sensors available. It was pricey, no question, however they added two upgrades to my order at no cost and threw in a few T-shirts.... SO I'd gladly pay them the extra for the sensor. All in all what I'm getting at here is I added the 40t reluctor to my original order and along with that FTI is shipping me a sensor too and make this not only a bolt it swap, but a plug and play swap as well. Very excited to receive the order!
Back in November when I first decided that a th400 swap was in my near future a member named Clinebarger posted in another thread of mine with part numbers for a pigtail, a reluctor, and a sensor. I remember looking at them and seeing that the sensor was for a Saturn vehicle and was less than $25 maybe? Once I have this all done I'd gladly pick one of these cheap sensors up and run it to see if they're in fact an interchangeable part. I'll see if I can find the old thread and post and put the part numbers in this thread also.
The below information is the information that a member named Clinebarger posted in my other thread regarding my th400 swap, this was from this past November. Hopefully you guys can shed some more light on the topic. I spent A LOT more than this on the sensor from FTI but as said, I couldn't care less. FTI has been outstanding in my ordering process and I'll gladly spend money with their company, and at least I'll know as of now that it's for sure the right stuff.
"The later production TH400's had VSS sensors.
VSS Sensor GM# 24232618
VSS Reluctor GM# 8655315
VSS Pigtail GM# 12085498"
