Vss color wires
Old May 3, 2018 | 02:55 PM
litle88's Avatar
Default Vss color wires
ive been searching, Im doing an m6 to th400 swap.
What are the colors of the vss sensor? Anyone?
thabks in advance.
Old May 3, 2018 | 06:00 PM
Jays_SSZ28's Avatar
green and purple. Always twisted together throughout the loom.
At least thats a ton of gm vehicles.
Is it a secret as to what you're asking about?
Old May 3, 2018 | 06:10 PM
Jays_SSZ28's Avatar
Not just guessing, only assuming. Assuming it's an f body.
Old May 3, 2018 | 11:10 PM
litle88's Avatar
Ok thanks I did it and we’ll see tomorrow.
One other question, I tried firing it up and the car will not crank. I have fuel pressure but no cranking. Any suggestions?
Old May 4, 2018 | 06:22 AM
Jays_SSZ28's Avatar
The neutral safety switch wires probably aren't connected.
Old May 4, 2018 | 06:44 AM
litle88's Avatar
which wires are those? Thanks
Old May 4, 2018 | 10:24 AM
Jays_SSZ28's Avatar
What vehicle?
Old May 4, 2018 | 10:27 AM
Jays_SSZ28's Avatar
Thats a hell of a modification list to not know anything about a neutral safety switch.
Those are the two wires that go to the switch that your clutch pedal would depress when you put it on the floor.
Those are green and purple too believe it or not.
Old May 4, 2018 | 10:33 AM
Jays_SSZ28's Avatar
I posted this december 2010
https://ls1tech.com/forums/showpost.php?p=14205407&postcount=87
The switch on the left is the stock switch.
The dark green and purple wires are the neutral safety.
The light green and brown are for the reverse lights.
IIRC.
