Deciding on 9 inch rear gear choice....
[/url]Combo - 5.3 btr stage 2 4.8 turbo cam, vs 7875 turbo, th400 w 3500 budget stall , ford 9 inch detroit locker w 4.11 currently... 276 60 15 tires in back
I know my rear gearing isn't right for my combo or a turbo car in general
What brands/ratios does everyone recommend? I am leaning towards 3.25 motive gears
Currently 3400 rpm or so highway cruising
Car is mostly street, but want to do some strip when it is all dialed in
What is a 3500 'budget stall' ? Is the budget stall typical in the sense that most budget stalls are 'loose'(inefficient-too much slippage) and then hurting your highway cruising and future strip top end trap speed runs.
Based on your facts given,3.25s' would put you about 2700rpm and 3.55s' at 2900.
How much power you making ?
Gears(higher numerical) are an equalizer when you're not making a lot of power,when you have power a lower numerical ratio is all that's needed.
I am around 500 tire at the moment on my lm7, but haven't turned it up much yet and it is RIICH in boost lol.... I have an L33 on the engine stand that I am gapping rings and hoping to run like 18lbs on going in sometime this winter etc...
Budget stall is a Freakshow performance convertor...
I am not hooking up on the street as the power hits violently....
Originally Posted by Jays_SSZ28
You're obviously not going to run with those tires with more power, or the power you have now.
Take into consideration future tire size when selecting rear gear,
That 275/60r15 will hook,don't even think of comparing it to something like 275/40/17 drag radial.
As far as Freakshow performance convertor,it could be a very good convertor. Excellent reviews.
