4l60e servo pin
The leak was fixed, fluid refilled, and it ran for a little while until 2nd and 3rd gear started slipping. I got it for $25, and trying to learn/figure out what happened....
The 3-4 clutches look dark but not burnt up, and the band looks the same. All other clutches are perfect and look new. The captured steel ball in the servo does not leak.
In removing the input drum the band wouldn't let it go and I had to take the servo cover off..
So I disassembled the servo to test the pin bore, and I discovered that the pin does not go all the way through the bore. It gets stuck at a machined ridge at the end of the bore.
See the pictures. The one with no pin is of the ridge - seen as a straight line reflected by a flashlight. The one with the pin is where the pin gets stuck and as deep as it goes.
Even though the servo retains the pin, should this ridge be there?
I have a 700r4 case (older version I know) and the pin bore does not have any ridge machined into it like this one - and he pin slides all the way through without getting hung up on anything.
If I remove the ridge, do you think it would hurt anything?
I am trying to figure out if my trans is a 60e or 70e.
It has the black harness connector and no 4l60e stamped on the case - but it has 4 pinion planets..
Do you know any other indicators of the difference between a 60e and 70e?
I heard the valve body is completely different but they share the same case - can you post a pic a 70e valve body?
I have a 700r4 case and this ridge is not there - yet the servo is the same...
Not debating durability, just referencing that cause he is trying to figure out if it's a 60e or 70e.
I think I saw in his other thread he has a 70e harness but 4 pinion planets so if the transmission has been gone through I guess it's unlikely the 3-4 clutch pack would be the stock one anyways
06+ might have additional wires for the input shaft speed sensor...but that's the only noticeable difference in the harness
If he has 4 pinions...he doesn't have a 65 or a 70
If he is rebuilding it...it doesn't matter how many clutches it had in the 3/4...he should be putting the proper amount in it with the rebuild
Yes that is my other thread with the black plug (supposed 70e) wire harness.
This trans is a stock - never opened up before, and I do not plan on putting it behind anything other than a stock Tahoe or truck etc etc...
The shaft has the ring and the pump has the speed sensor and the harness has the extra wires for it.
Just want to make sure I get the right rebuild kit for this trans - not a trans expert but I am sure there are some here, so I appreciate any info.
Seeing the black wire plug, and the absence of '4l60e' stamped on the case just got me wondering....but being that it has 4 pinion planets I guess it is safe to assume it is a 60e...??
If you don't have a band worn to hell then you shouldn't be worried about this ridge in the case either. DON'T file it down, or try to drill it, or anything like that. The servo pin bore has to seal 3/4 clutch oil...if you screw up the bore and create a leak you can prettymuch kiss your 3/4 clutch goodbye after rebuild.
