Missing valve body gasket
I doubt the motor oil will cause any major issues when combined with a whole bunch of ATF. However, before I call and cuss this guy out... what would happen if I ran this transmission with no valve body gasket? I'm not planning to but just curious.
Sounds weird to me. Since you were in it and seen all the internals was it actually rebuilt?
I'd go shove that trans up the guys *** and get my money back, sounds like you got a core with a swapped valve body.
At this point would take less money and less time to just install the valve body gasket and then install the transmission than it would to drive back to that shop. If anything is wrong after installation though, I plan on cashing in on his warranty.
Why not just rebuild your old 60e and change the shaft on it?
This is either a fishy story...op isn't very bright...or I'm missing something that makes this all make sense
To answer your question though. I took this route because no one could answer what was wrong with my last transmission that was rebuilt recently. After a full teardown, I couldn't find anything wrong with it. So replacing parts that I know are good with parts that are also good is not exactly the most productive use of time. https://ls1tech.com/forums/automatic...orrection.html
That said, I decided it would just be easier to "hit the easy button" and get a rebuilt transmission and spend 30-45 minutes swapping the output shaft. I didn't realize I would be getting a transmission from a shade tree mechanic.
At that point, you pull the snap ring off of the output shaft and slide it out the rear. All that's left is the front planet, sunshell, and sun gear...then you're at the rear support and low/roller clutch.
I mean...you're prettymuch doing 80% of the work of a rebuild...so do you just not know how to disassemble clutch drums?
So I ask the question again...why not just rebuild it yourself if you are going to go that far to swap the output shaft?
P.S. I stopped following that thread when you didn't know the difference between 1st and 4th and 2nd and 4th...then you started going down a rabbit hole of diagnostics that was not getting you anywhere. Can't help those that just want to do it their own way.
So it took me 2 days to rebuild my transmission the first time which included lots of dimensional checks, the rear piston assembly, and the pump which you aren't addressing and all of those suck up a ton of time without a lot to show for the effort. It took me 45 minutes to change the output shaft and put everything back together minus the valve body due to the missing gasket. That's certainly not 80%. When I diagnosed the clutch packs on the first transmission after rebuilding it and having my issues, they were all perfect so replacing them doesn't make any sense to me. Even if I rebuilt the things you mentioned above, you aren't addressing the possibility of the pump or some valve body bore being worn excessively in an area I can't see causing my problem. The pressure was on the minimum end on my last transmission which could be torque converter related as well and I personally have no way to test that.
So the math of what you're suggesting is to rebuild the old transmission with roughly a $200-$250 rebuild kit and replace all of the things I know are currently good. The pump and torque converter both check good from all the checks I physically have tools to check but I have a pressure related issue in the transmission so add in another $200 for the torque converter and $200 for the pump since I don't know of any other way to restore low pressure and wasn't getting any help in my previous thread. So my math said that I'm over $600-$650 deep into rebuilding my old transmission and replacing things blindly without knowing the real problem. Without even addressing solenoids or the valve body which could be the problem as well, the simple solution in my mind was to trade in my transmission for another one with a 2 year warranty for $800.
You might ask next why I'm not just taking the transmission back and getting them to fix the issue and that's a very valid question... Mostly it's because I'm sick of tearing transmissions down and it's a 300 mile round trip. The only shops locally who do transmission work couldn't even look at my transmission for over a week and I need this vehicle for an offroad event in 3 weeks so my confidence was low that I would have a working transmission back in that timeframe.
regardless, there are about 5 different ways I can easily mark a trans as it's being put together that tells me if it's been rebuilt or at least torn apart.
I hope you find your issue, As performabuilt said, it would not surprise me if it still worked without the gasket. Not recommended but possible.
Good luck sir
And those "regulars" also tried very hard to help in your other threads, as did I. We all had slightly different ideas of where the problem was and what caused the codes, and I am disappointed to not learn what the problem was. When we have different ideas, we don't care who turns out to be "right", just that we help someone get their trans and car running.
Finally, why not add your city/state to the Location field of your profile. Someones there is an expert here who lives near you and is willing to stop by and help.
Good luck and keep us posted on your progress or lack thereof.
