4l80e rebuild
I didn't install it right!
Now its right. It was trying to engage 3rd and 4th at the same time with this not being seated all the way in. I'm dumb. Lol
Corrected now
Corrected now
That was a Bummer of a build mistake... Such a small part can cause a big problem (especially when you introduce a leak into a hydraulic circuit LMAO).
Congrats on finding the problem and you are quite fortunate that this was nothing major and didn't waste too much $$$ when all is done.
And/Or it could be a worn boost valve, caused high line pressure and broke the reverse servo and possibly blew out the seals in the direct drum.
All though, with a good band and good reaction carrier... 0.1875" is considered max travel by GM/ Hydra-Matic. I do not recommend this.
I would aim for 0.1250" instead.
Other times I have seen the reaction planet carrier be installed under specification (diameter too small), or have the incorrect design low/ reverse band installed.
Search for this subject with "Sonnax" in the search terms as well via google. You will see some decent articles on the subject from Sonnax.
In regards to the front pump seal blow-out... The front pump seal drain-back passage should be enlarged over the stock dimensions to 0.2500".
Clean out the pump half completely with brake parts cleaner and compressed air.
Then ideally install a new pump bushing (Teflon lined ideally) with red thread locking compound. Last install a new pump seal (pack the inside of the seal and cover the coil spring with Transmission assembly lube. If you do not have any, purchase a small tub of Vaseline, to use instead. Apply red thread locking compound to the O.D. of the seal).
Excessively high line pressure in reverse may also be a problem. I usually delete the reverse boost circuit in these transmissions anytime I raise the line pressure.
Should you like to discuss this further, please message me and i will go over photos and instructions with you.
This procedure also helps to prevent the "late model" low/ reverse servo piston failures.
Some what less pressure is even fine for stock.
In the reverse gear range, the line pressure can be up in the 300 PSI range. Which is no good and causes parts failures.
Line pressure of over 600 PSI has been regularly seen in reverse, usually when there is excessive pressure regulator boost valve wear.
both sides look the same. Ive never had trans alignment issues until now. What would have caused the misalignment? I don't know what the pressure was cause I didn't have a gage on it at the time and the fluid was pouring out of the front of the trans.
TAKE CAUTION to drive bushings in square. Alot of times it is best with a press, but you can hammer them into place too if you don't have access to a press.
