3.8l camaro auto tranny compatible with 5.7l camaro auto tranny???
You need to change the bellhousing, torque converter, input shaft/drum, and pump stator/whole pump. And probably the 2nd servo and accumulator in the valve body. And the 1-2 3-4 accumulator springs.
Assuming its a two piece case.
No its actually a one piece case its a 4l60e from a 97 camaro with the 3.8l but im guessing it wouldnt fit on the LT1 engines since the bellhousing on the LT1 have a 90 degree angle and the one on the 3.8l have a 60 degree angle bellhousing am i correct
It won't work at all then. There are no adapters, nothing (I've seen this question asked a million times).
Yes im trying to sale it i took it of my cousins camaro before he junked it. The tranny only has like 115k miles on it and before he had his camaro wrecked it was driving like new and shifting real smooth
Thats what i was thinking that it would only fit a 4th gen f-body with the 3800 series engine well thank you guys for all your input.
