4L60E no TCC lockup
After installing, everything works except no TCC lockup.
Dropped the trans again, pulled everything apart again, cant find anything wrong.
Vacuum tested the TCC apply valve in the pump and TCC regulator valve in the valve body, both around 15ish.
Any suggestions on what to check? All I can think of at this point is a dead on arrival torque converter =/
Have the solenoids, the internal wiring, the external wiring, and the PCM been looked at yet?
I did command the PWM solenoid with the tech2 and i can hear it 'click'. I also applied a 9v battery to the terminals and it clicks. I also used a 9v battery to the TCC solenoid that goes into the pump - are they the two solenoids your referring to? - both of these checked out. Also checked resistance ranges and they were in spec.
Note this problem was not present before the rebuild, so its an issue i've introduced somehow.
Install this...slip 95% likely to go away
http://www.fitzall.com/supportDetail.php?A74741Q-188
With the tech 2, can you see the pwm duty cycle that is commanded?
How do you have the valve lined up in the pump?
Did you install new solenoids? The solenoids seat with very small pintles and even if they ohm test ok and "click" they may still not work right.
If both valves are in correctly and vac check well, and both solenoids are good, and the o ring was on the shaft...then you're looking at a short lift of issues left.
Most likely being a DOA converter. Which is pretty odd.
I've attached the entire fluid circuit for the TCC lockup...it is fairly simple...and you've eliminated most possible issues.
Good luck
Good luck
Yes I can see the PWM duty cycle, it goes up pretty quick after 4th gear is engaged (after it reaches operating temp), basically it goes 25, 50, 75, 99. Regardless of the duty cycle commanded, the slip speed stays the same - anywhere from 100 to 180ish rpm depending on throttle applied. I replaced the PWM solenoid as part of the rebuild but not the tcc solenoid as that requires a full wiring harness replacement (although maybe I should do that as part of troubleshooting).
The TCC apply valve in the pump is just installed as stock, i took it out like three times to be sure it was orientated correctly.
I think i'll replace the wiring harness, torque converter then re-install and go from there.
If that fails then ill give up and take it to a professional.
Looks like they are going to have to tear down and rebuild the whole thing as the trans shop i took it to cant find the problem either.
If i buy a new valve body, pump, and torque converter do you think that would solve it? Have done every test in the book and everything checks out.
The only thing not tested, which the shop is going to do, is the TFP switch. This was replaced during the rebuild.
Just piggyback into the harness and ground the TCC solenoid with a switch in the cab. The computer can command it all day but if the signal never makes it to the trans...it's not going to matter
I can command the TCC solenoid using the tech2, when I do that with the engine off I can hear it 'click' - I know thats not a sure fire way to tell its working but it suggest its not a wiring issue. Regardless, i'll wire a switch into it and piggy back it to a 12v wire and see if that makes a difference.
Have purchased new valve body to determine if there's something I did wrong with the ream ( even though it passed vacuum test)
I also need to double check weather my pwm is ec3 or not, as the sonnax valve I got is only good for non ec3 pwm.
At highway speed the tcc slip is around 200ish sometimes a bit more If there's a bit of a hill. (After tcc is commanded on)
Regardless, there's definitely no lockup even when the computer commands it in 3rd gear.
